Hello Everyone,
I'd like to share with you my first purchase for attempted servicing.  By this I mean the watch I want to service one day, after I have developed myself sufficiently in watchmaking skills so as not to break it.  I am currently watching videos like mad and looking around for pocket watch movements to ease myself in, as well as reading as much about watchmaking as I can.
I bought the watch locally here in Hong Kong from a nice man who has (to me) a large collection of about 75 watches.  He doesn't service his own timepieces.  Instead, he pays to have crystals changed and movements serviced.  He has quartz watches, and also mechanical ones, and he has very many beautiful watches.
I suspect this watch (which he never had serviced in any way) is a bit of a foundling now.  Maybe he recently dropped it.  Maybe it's not keeping proper time.  Maybe he's tired of it.
He bought it three years ago from a local dealer of "junk watches", which here in Hong Kong means anything that's not a pinnacle, name-brand timepiece.
Anyway, I was wondering if anyone had any advice or background information on this watch?
I could use the help please.  Here's the photos from the listing - the watch is on its way...
g.
Hi It has the look of 60s watch. The name on the dial is not nessesesary the manufacturer that witll be on the movement its self. When you get the watch remove the back and look ubnder the balance wheel, there should be a logo and a number  this is the maker and caliber of the movement. If possible post pictures of the movement for further help.   Cheers
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
