Rolex 1570 calendar stud issue (from a 1600)
Hey, servicing a 1570, all went smooth (except it needs a new balance) when I run into this. It looks like someone used jb weld or something to secure the nut. I thought I was going crazy. I cleaned out the nut and post and I cannot get it to thread (reverse thread that is.)
I can’t tell if it’s the nut or the stud that it the problem but am leaning towards the stud.
I’ve tried to repair these types of things in the past with limited success, once I bent a bridge trying to press a post out.
so I ask you? Try to press it out and make a new shaft? Cut the stud and make a simple collar/snapring as it’s not really a “weight bearing part”, or use jb weld again (it seems to have worked fine for over a decade.)
thanks
dan
4 hours ago, Kalanag said:
It‘s about this nut and its threaded post:
Yeah. This is the screw. It is reverse threaded (that’s what the three lines indicate). I think what happened was that at some point someone else attempted to work on the watch and stripped out the stud. When I took it apart it was very stuck together and it had this thick grey gunk on it. I assume it was loctite or jb weld or something.
18 minutes ago, clockboy said:
Mild heat normally works with loctite. Finding replacer screw might be a challenge..
Yeah, I got it off and all cleaned up. But in the picks you can see the stud doesn’t look normal. I can press the stud out and machine a new one, but there is some risk to the plate. Any stainless steel plate of the same diameter should do fine. Tapping the end is challenging but doable.
the thing is, a spring clip would probably work just as well. All the nut does is hold the gear flat, there isn’t much torque on the gear.
or, some more jb weld. It worked for a decade…
Just to follow up. This was actually a lot easier than I had assumed. The part is available as a generic from a lot of vendors. I just used a staking tool and pressed the old one out. No problems at all. Here you can see the threads have been destroyed.
now, to find a balance for less than a grand…
thanks
The hairspring was bent and had been repaired before but it didnt keep good time. I made a half hearted attempt to bend it back but it was kinked. I sourced another balance and replaced it with no issues. They are stupid expensive thought.
Otherwise, it was a very straightforward service.
  • 10 months later...
I'm glad it turned alright! Thank you for sharing.
In the absence of having the specific wrench for that calendar nut, any suggestions for what to use or improvise with? I've been searching for the specific tool without any luck.
Thank you!
    • my understanding is message boards don't really use much space at all if they're basically just text. as why their websites out there that will give you free message boards of course they control the advertising but they're just text based I thought the message board already was backed up in fact was backed up multiple times? One of the things that is a real killer for message boards is file attachments. As people get faster computers they think nothing of attaching big files. Then we get a lot of big files reattached multiple times a somebody new post the question we will post things again and again and I mentioned there's a heck of a lot of file duplication it be nice to figure out some place to put all the files and not have them on the message board at all. then? The last time I checked Facebook maybe I wasn't paying attention to something? So I just now checked his Facebook watch repair group he was last seen on the 14th and I just don't remember this picture? Maybe could that be what's distracting him?  although he is on the Facebook group may be just doesn't like us anymore?
    • Sorry I don't know much about clocks and this post seams to have been overlooked.  Hopefully someone will pick it up now.
    • I 'll remember my university days... Thank you very much!
    • I’m fairly new to this and have worked on maybe 30 or so vintage and new movements. I recently went through a NH35 movement that I picked up with low amplitude. 140-150 degrees and impossible to regulate. I did find that the train bridge was not flat and when the screw nearest the barrel was tightened the wheels no longer spun freely so I replaced that with a spare and all good.  I cleaned it and lubricated it, including the balance cap jewels and it came right up at 220. I could get the beat error down below 0.5 but I’m chasing the rate all over. It will be down -15 and I’ll just touch the regulator arm and it will be up +15. This is a practice movement for me as I want to learn and improve making positional error corrections on the Etachron system.  The amplitude has fallen off a bit as well, 200. I’ll let it run overnight but is there anything I’m missing that can cause the rate to change so significantly with a very very small movement of the regulator? Could the hairspring be damaged and very particular to both the  regulator and stud position?  Could the regulator pin positions off? Either too open or closed?
