Happy Saturday all!
I recently acquired an Elgin timer /stopwatch from 1943. Broken staff, which I believe I have located at Otto Frei(hopefully). But the tragedy is that a part of the stopping mechanism is completely missing from the watch; the connecting pinion.
Rarely have I had the opportunity to work on something like this, and I even found the tech specs online to assist me - a step by step guide! I want so much to continue working on it, but it will be a lost cause if I don't have this part. I know it's a shot in the dark, but anyone know where I can get a hold of this? The movement is grade 469, model 21. It’s a 16s.
You could try Dave Coatsworth,  daveswatchparts.com
Even if he doesn't have the part,  he may be able to send you in the right direction.
Good Luck!
Edited by dadistic
Good Luck!
Thanks, sent an email!
  • 9 months later...
I hope that you were able to locate the pinion! Where did you find the spec sheet? I just found one this past weekend and it would be my first time tearing into one.
Thanks!
  • 5 months later...
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
