Accurist Automatic Shockmaster, 9ct case, 1960's
Certina Bullseye Incabloc, Manual wind, sub second, 1960's
Ingersoll Auto Calendar, GP with GP Bracelet, 70's/80's
Tissot 1853 GP Quartz, 1990's?
Cyma, 9ct case, manual wind,  dated 1960
Baume & Mercier Hampton, SS Quartz, rose gold dial, sub second at 6pm, 2011 on
Baume & Mercier Riviera, SS Quartz, white dial 2011 on
Rado Jubile, Ceramic bracelet, 4 diamond black dial, 2000 onward
Tissot  18ct Gold Run Sapphire, Quartz, 2002 dated
Birch & Gaydon Land and Water Trench Watch, Cushion Case,  Ref 3110972, 1935-1938
Zenith Stellina, cal 120, ref 4752357, SS case Gold hour arrows, 1955-59
Longines Flagship, Square case automatic, SS, cal 7678, 1970-79
Visible 9ct cushion case, movement signed Visible, manual wind, 1930's
Unsigned 9ct cushion case, white porcelain dial, Red 12, Roman numerals, dates to 1924
Rolex Datejust 1603 SS from 1973
Waltham Maxim, mesh bracelet, SS, manual wind, 1956
Roamer Red Sea auto, SS, 1960-69
Longines 1172.1, GP, yellow gold dial, manual wind, 1980-89
Buren Lux, solid silver, full hunter pocket watch, manual wind, 1903
Raymond Weil Tradition, SS, Quartz, 2011 on
Raymond Weil Tango, GP case and GP bracelet, Quartz, 2011 on
Schwob 9ct ladies manual wind cocktail watch, 1950's?
Jaquet Droz 9ct manual wind, 1950's
Longines 9ct, gold dial, manual wind, 1957
Omega seamaster cosmic 2000 automatic, 1980's
Seiko Solar Chronograph, Quartz, white face, solar powered. 2011 on
Carvel, solid silver case, manual wind, modern, for parts.
I haven't counted the watches I've bought for my beloved wifey with the expensive tastes.  These include JLC, B&M and Rado.
This is the first time I've sat and really thought about how many watches I actually have.  So pleased my wife doesn't know the half of it.  There are another couple lying around somewhere.  They'll turn up.  I'll put up some pictures once I get around to organising these in some sort of order.  Anyhoo, that's where it stands at present.
I hope there are one or two that elicit a response or two.
Cheers
Frankie
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
