Hi all,
after a fall, the hairspring of my 1963 seagull watch broke... Do you think this part can be mounted on the st19 ?
https://www.aliexpress.com/item/1005001489146055.html?spm=a2g0o.productlist.0.0.257612aeI7LOVE&algo_pvid=d0a9cebd-e083-4df4-a550-9b08285172e4&algo_exp_id=d0a9cebd-e083-4df4-a550-9b08285172e4-1&pdp_ext_f=%7B%22sku_id%22%3A%2212000016318348311%22%7D&pdp_npi=2%40dis%21EUR%21%212.85%21%21%211.05%21%21%402100bddf16589951991436589ed018%2112000016318348311%21sea
Thanks !
From the description,  it doesn't seem so. Unfortunately many Chinese seller don't really know what they are selling.
Does this Seagull happen to be a clone of the Orient caliber 46941/46943 for which this balance is (hopefully) made? Obviously not!
See here: Orient 46941
Edited by Kalanag
What I have learned so far is that spare parts for Chinese movements are very rare. The manufacturers want yo to buy a new movement which is often cheaper than part + labour.
forum watchuseek
Edited by Kalanag
  • 2 months later...
Did someone tried  any "compatible" ST19 balance assembly ?
replacing it (when broken) is not a big labour ... and should be cheaper than 90-100 $
Edited by Squeme
typos
  • 1 year later...
I finally ended buying non-working ST19 chronographs (Seagull 1963, Sugess, Pierre Paulin, Merkur, ...) and ST1901/ST1903 movements ... just to get parts 🙄 no other solution by now
so if you have some in bad shape, non working, please get in touch with me ...
(for example low balance amplitude, i took it in slow-motion https://youtu.be/HQZEG9A2Iso)
Edited by Squeme
  • 1 year later...
1 ½ year latter ... for the people (such as me) who still need ST19 parts 😏
🙏 there is now a seller who recently propose some ST1901 parts !!! 🙏
https://aliexpress.com/item/1005008240588807.html
which was not available before,... i hope it will be helpful !
i would have probably used this, if i didn't get a set of parts from the official shop,
in one of my reset lever replacement
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
