Hello, I have an Omega De Ville Dynamic (men). On the back of the watch it has the "De Ville" carving and also reads "Tool 107". The crystal is cracked and needs replacing.
Does anyone know what the reference number for the crystal replacement is? Or what diameter should I be looking for?
Edited by QuadMachine
Hi Before chasing up a crystal check what its made from If its acrylic you may be able to polish out the scratches with something like Polywatch or auto chrome cleaner Sovolautosol and save you a few quid. If its crystal you will need to remove it and measure its size and the case rim. Check to see if it has a gasket  as well.    you will need a crystal press and or a crystal lift tool depending on the material  and also whether its got a tension ring on the glass.
The reference is inside the caseback. Replacing this crystal isn't difficult still some specific tools and knowledge are necessary, so if you have a reputable repair show I would recommend to give them the work. You can still buy the replacement crystal yourself.
I believe it is acrylic but there is a crack which lets in air and dust so needs to be replaced. I just don't know what size/model I need to get
Do I have to remove the crystal and the movement to get there?
No, it's a screwed caseback with an uncoventional way to hold the strap.
https://r.search.yahoo.com/_ylt=AwrIQdf5BOhiXccA2QV3Bwx.;_ylu=Y29sbwMEcG9zAzEEdnRpZAMEc2VjA3Nj/RV=2/RE=1659401594/RO=10/RU=https%3a%2f%2fwww.cousinsuk.com%2fproduct%2facrylic-glasses-by-size%23%3a~%3atext%3dMost%20Popular%20diameters%20used%2cby%20Omega%3A%20%C3%9829.6mm%20%C3%9830.6mm%20%C3%9831.6mm/RK=2/RS=sbr4TJAncHsVxVxJaNPSuaYRmMc-
This is the page from cousins website regarding omega acrylic glasses. As you will appreciate there are many sizes. The normal way is to remove the offending crystal and measure  it across 9 -3 position  then add 0.01 to the size.  You will still need tools to fit the replacement
I have one and it is not a screw back it is a front loader the 107 tool is to remove the crystal.  The ring on the back just holds the special band on.  I have a Tissot that is the same.
I agree that it has quite an unusual strap. I don't think I've seen one with such radical taper.
@QuadMachine, It can be frustrating to try to find the right factory crystal for wrist-watches. If the maker didn't provide a catalog with crystals to match the case number, which not all did apparently, your best bet probably is going for something generic. G&S, Steinkreuz, etc. G&S catalogs do list a lot of their "PA" and "ET" (Ever-tite, which have tension rings)  crystals with watch brands noted. Good luck. I hope you have an easy search and replace job.
Based on the following links, I think my watch should be Ref 166.144 Cal 1012:
even with that info, I still can't figure out where to get a replacement acrylic crystal for it
A better way to get your case number would be to take your case back off and see what it is. This way you avoid any unpleasant surprises just in case for some reason it's not the same.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
