Just happen to be in Vietnam this week for a few days, scouting around for watches.
Can't find anything of much interest, millions of fake but I'm more in old unique watches. There are many old Omega but a bit cautious on it since there are many old fake.
Few shops displaying these make to look old Crystal Ball "Omega" at USD 50 each before bargaining. I did not bargain because I think they are not genuine. When few shops selling same item, it can't be real antique.
Junk street in Saigon, not many watches. Mostly statues and porcelain.
This Wittnauer watch they asking 4000000 dong about USD180, should not be that price.
Any one has any tip or familiar with Ho Chi Minh do let me know where to look for watches here.
Being a Tourist in District 1 is not a good place for reasonable price vintage. I can pick up better watches back home or on ebay.
Some enthusiast advise me to be careful of Frankenwatchs or some called it "United Nation Watches" due to mixed and match parts even in a Rolex.
Sent from my SM-G900F using Tapatalk
Fascinating stuff, Affnan - it looks difficult (from the photographs) to tell the difference between real and fake!
Those in the photos are real old watches but the price are steep for the condition it is in. The fake are mostly Rolex, Omega and other high end branded watches. A Seiko chronograph I think those 6139 they are asking for about USD 250, that is too much for it, even if I bargain he would expect USD 200 for it. The most I value it at USD 100, as a Tourist in Vietnam it is not a good place for watches.
But all is not loss, the wife and kids are very happy.. clothing are dirt cheap.. :) at 1/3 the price back home.
Welcome to Vietnam. I think its not a good idea buying vintage watches in strange place. Foreigner tourist are usually asked for much higher price. If you want to see, go to department stores. Also, here is a shop selling some luxury brands, mostly are used watches, address is 99 B Ly Tu Trong, Q1 ( District 1).
I am from Malaysia and what I've found is that watches that have been local from new have been thru the hands of 'bodgers' with a lot of parts missing/wrong. Similar is found in watches from other Asian countries and Africa. Since I discovered ebay, I have more or less ceased buying watches locally unless they're priced too cheap to resist!.
One thing in particular is the case clamps (where originally fitted) are usually missing.... ?!?!
Anil
Anil
This is something for all of us to heed. Thanks for posting Anil.
One of the easiest ways of telling a fake from the real thing would be the hands. The fakes always had cheap looking hands, not refined, if it came with a bracelet that would be a giveaway rough around the edges not a nice finish not what you would expect on high quality watches. I don't know about today as even with fakes I expect things have improved.
    • Very interesting! I answered the mail from Longines, explaining that I was a bit disappointed and that I wouldn't ask for a costly confirmation for a watch which isn't a high-end one ... and I received another email explaining that they couldn't not certify the authenticity of the watch, but they could specify that, according to the serial number on the caliber and to their handwritten records, the watch was produced in 1938. Great! @Mercurial I will take the measurements and will keep you informed. Thank you all. This forum is incredible 👍
    • Good stuff, thanks!!!  I'm going to save it and re-read your post and watch the video again.  I have a few follow-up question:  My understanding is that the spring vibrates or breathes between the the two regulator pins. When the pins are fully open the effective spring length is from the stud and theoretically no rate adjustment can be made by moving the regulator arm. As the pins are closed the spring gets closer to one side of the regulator block but doesn't touch a pin. You can still move the regulator carrier the entire terminal curve without upsetting the coils.  The rate can now be adjusted using the regulator because the effective spring length can be modified.  My question is: Does the hairspring bounce off and touch one of the pins as it breathes? Is that why the effective hairspring length is adjusted by moving the regulator?  And follow-up: How is amplitude affected by the spring between the pins? Does fully open pins, dial up position = max amplitude?  When spring adjusted to 1/2 width still = max amplitude? When I have crown down gravity is pulling the spring against one of the pins and I would expect rate to go up and amplitude to go down. Is that correct?
    • A quick Google for Longines 25.17 found several similar watches - like this one with writing on the case back similar to yours https://benjaminmarcello.nl/product/longines-cal-25-17-tank-from-1938/
    • Apps like Watch Accuracy Meter can be inaccurate, and will read some watches better than others.  What daily rate does Watch Accuracy Meter give you if you check the Longines once it’s been running for 24 hours? Best Regards, Mark
