There Must Be Better Way Department: Getting Oil Out of Bottles
I agree with the advice above, everything you have there looks to be worth keeping. There is the possibility of using the parts, screws and jewels in future repairs. Wheels are useful when learning to use the Jacot tool. You will inevitably snap some pivots, so it’s best to learn on wheels you can afford to damage. You can also practice other new techniques on these parts, such as reaming out a hole and fitting a friction fit jewel. Best Regards, Mark
Rather than rubbing with pressure, you’re far less likely to damage the dial if you use a rolling action to clean it. Wet a q-tip or similar shaped foam swab and roll it over the surface. It’s slow, but it’s very gentle. I hope that helps, Mark
It can be difficult to keep track of all the different screws on a movement like this, you can save yourself a lot of trouble by putting each screw back on the movement after removing the part it secures. This ensures every screw stays in the position you found it in, but if the watch was serviced by someone willing to glue the dial on, it’s possible that some of the screws are already misplaced. You mentioned that the chronograph functions. That being the case, I suggest you keep all the eccentrics that adjust the depthing and engagement of the chronograph works in the position they’re in, unless you have experience with setting up and adjusting a chronograph. Take plenty of photos, and you should be fine during reassembly. I hope that helps, Mark
By HectorLooi · Posted
Hi! Welcome to WRT. I launched a particularly springy battery clip into space last week. Usually I'd listen for ricochets and search in the area where it landed. But in this case, I didn't hear a thing. Spent 3 days searching for it but nothing turned up. Probably have to wait for SpaceX to go up and retrieve it. From your moniker, are you an endodontist (dental) or endoscopic surgeon? -
I am really pleased I have managed to restore this movement, after a good clean and installing a new mainspring she is running like a charm! I now need to source a winding stem and a watch dial face but don't know where to start looking! Help Please! I believe the movement is listed here under Early Omega Wrist Watch Movement: https://www.vintagewatchstraps.com/movements.php
