Removing Rust In Place (Prior to Unscrewing)
Gramham
Hello Everyone,
In an attempt to accumulate some practical Watchmaking skills (and not just constantly talk theory) I want to go about refurbishing three major components in the Winding Work of a Pocket Watch Movement I recently purchased here in Hong Kong, as a practice piece:
https://pocketwatchdatabase.com/search/result/elgin/23687805
The three components in question are:
- Click (or Ratchet Wheel Pawl)
- Ratchet Wheel
- Crown Wheel (or Main Wind Wheel)
Here's a photo of the movement in question, with the components identified:
Here's my question:  How do I get the corrosion off the screws prior to unscrewing them?
In a really interesting Verge Movement Restoration video I recently watched, the Watchmaker used "Turpentine Spirits" to loosen rust before taking components apart.
http://www.youtube.com/watch?v=EwmzYC0zOF0&t=2m45s
Can my UK brothers help me out?  Is "Turpentine Spirits" the same stuff that we Canadians simply call "Turpentine"...or is it a distillate of our "Turpentine" and something else?
Also, is "Turpentine Spirits" the only solution available, or are there other or better solutions (pardon the pun) that I can use to loosen potentially rust-welded components?
If this was a different machine (car, boat, lawnmower) I'd have a bevy of other options...but I'm new to this so I want to be careful and draw on collective experience.
Lastly, this is a very mature site.  If there is already an existing discussion about this, I'd be happy to get just a pointer to it so I can review and not force a re-run of a well-discussed topic.  I'd prefer to draw my own conclusions on my own time in those circumstances, and not waste everyone else's.
Thanks in advance!
g.
Edited by Gramham
Premature Submission
The highly respected Dutch watchmaker Kalle Slaap puts a drop of WD40 on the screw and let it soak a while. But seeing the screw heads in your pic I wouldn‘t do anything other than just unscrew.
Edited by Kalanag
Hello Everyone,
Thanks for all the tips!  I got the wheels off and I have decided to started with the click.
I'm not done yet.  (A) There's still pitting  at 10 O'clock; and (B) I want to dress the screw notch a little bit.
But I thought I'd put a preliminary image up here to just get some fast feedback and I am also trying to remove as little material as possible.  I'm using a dry stone, a pair of utility tweezers and (sometimes) my fingertip to "drag" the parts across the fine side of a Carborundum stone, which I got a long time ago to sharpen my kitchen knives.
Here's the stone...
Does anyone have feedback for me?
g.
2022-08-26 Update:
I dare not remove more material from the click, for fear of leaving the screw too proud.
Sadly, I do not have a dressing tool small enough to chamfer the screw notch.
Here's the latest results.  Apologies for the bad focus, I am using my mobile phone to (badly) take 2X photos.
Next steps are:
- A 12-hour bath in some white vinegar to clean corrosion from the back and rim
- A dip in baking soda & water to nullify the acetic acid in the vinegar
- A quick bath in IPA to get rid of any water
- A little blow dry to get rid of any traces
Does anyone with more experience disagree with the above protocol?
g.
Edited by Gramham
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
