Excellent tuition as always Mark.
Like clockboy I am curious about the rust treatment you prefer. It appears that you re used the stem so was it chemical or elbow grease or a bit of both.
Cheers,
Vic
Edited by Vich
Lovely job, Mark. What a coincidence that the rust appeared in the same place in both watches. Might that be an inherent design fault? Some watches do have them.
Great job Mark, incredible finished result. Do you use Evapo-Rust or bicarb
No - I don't like using chemicals if possible. I go over them with a fibreglass scratch brush. The exception is the barrel arbor which I polished back up on the lathe. BTW - the watch is going extremely well.
I use the glass fibre scratchers always a bit awkward on small parts but very effective. Often wish that someone would make a glass fibre "scratch " wheel to fit my dremel.
 Cheers,
Vic
Oooh... I don't think that would be safe :) the little fibres are horrible - would be like mounting a cactus to the dremel. I have to say though - the Scotchbrite wheels are really good for the pendant motor/dremel.
http://www.cooksongold.com/Jewellery-Tools/Scotchbrite-Pendant-Wheel-prcode-999-ACR
Just make sure you use eye protection as I found to my immense discomfort when I first used one!
I have looked at these before as Proxon do them as well. However not sure how abrasive they are so I have avoided them as its so easy to go to far when using lathes, Dremels etc
I couldn't do without my Dremel but like George I always finish off by hand
(just realised what I have written - please resist lads I was actually trying to be serious for a change)
Cheers,
Vic
Can't express how rewarding this is.
Your unselfish efforts are greatly appreciated.
Thanks for sharing your knowledge/wisdom,
Dave
  • 4 months later...
Happen to be working on a PUW1261 with similar rusting of the stem into the clutch wheel and winding wheel.  I cleaned off the worst of the rust with a fibreglass pen (well away from my other watch work as the small fibres get everywhere!) but could not budge it even after soaking in deodorised kerosine (BBQ lighter fuel) for a few hours. I then left them overnight in Plus-Gaz and they came apart with a good tug.
I cleaned off the worst of the rust again with a fibreglass pen . I then soaked overnight in Kurust (which I used to use on rusty car panels!) which converts all the rust (Ferric Oxide) into Ferrous Phosphate which is like a protective layer.  The Kurust contains phosphoric acid which converts the rust, (I gather well known brands of cola also contain phosphoric acid and will convert the rust but not tried!), the parts should be thoroughly washed in water and dried after treating. The reason for doing this treatment is to prevent the rust reforming as it surely will if microparts of Ferric Oxide are left in the material without being converted (of interest is that most greases contain some water and so can restart the process on their own if not serviced regularly!).  The phosphate left after treating will prevent further rust formation. The phosphate layer is mid/dark grey and can be cleaned off using the fibreglass pen again and/or 1200/2500 wet and dry to get back to a bright finish with the ingrained phoshate still left.    I finished off the square hole in the clutch wheel by applying a paste mix of diamantine and oil to the stem and working it until it was nice and free and the stem part polished up a bit, then cleaned off with a wash.  All parts where then put through a normal clean cycle.
    • Bad news: Longines doesn't provide this service free of charge any longer. I have to ask for an extract from the archives or a certificate of authenticity, but I'm afraid it's not worth the cost for this watch. Too bad 🥴
    • Tool for removing or pressing the bezel? Most likely you have to remove the bezel (with a knife) before removing old crystal or inserting a new one. You can press the bezel with the crystal press if you have a suitable die with straight walls or otherwise a die that has enough clearance that it doesn't touch the crystal when pressing the bezel.
    • This will be my first crystal replacement, I have a press, but looking at the watch I wonder if I might need a bezel tool also. Any and all help appreciated.
    • I'm not entirely sure you fully understand what he's doing in the video. For one thing he's giving examples of things like about 16 minutes he talks about opening up the regulator just a little bit. Opening up the regulator slows the watch down to compensate for that he moves the regulator fast and now it's keeping time again but the regulator pins are too far apart. I have an image down below on top of it shows the effect of regulator pins and amplitude. If the regulator pins are farther apart than the example down below then at a higher amplitude timekeeping will be much worse. Why the regulator pins are supposed to be adjusted as an average rule approximately twice the thickness of the mainspring itself. In other words if you look at the spacing it have one half of the hairspring thickness on either side of the hairspring itself. There is like he talks about the video a little bit of adjustment here and there. So in his example where he opened them up it will really dramatically screw up timekeeping based on amplitude. Then when you get to the 20 some minutes like you say he is adjusting the regulator pins closer together to get a more even timekeeping based on amplitude and amplitude changes are caused by going to various positions. Then and the other example of the image down below regulator pins too far apart and they hairspring is not centered and look what that does the timekeeping. So hairspring is supposed to be centered regulator pins are supposed to properly spaced. Then you get reasonably even timekeeping like it shows in the upper image. It's not like we're regulating out positional errors like poising errors because that's something entirely different.   In the part number above and in the video both of you left off details. I which version of either of your watches I will just make you's timing specifications for your watch down below may specify how you're supposed to do it other words you wind up the watch fully wound up you wait 10 to 60 minutes in the four positions it should be within 60 seconds. Yes it can be closer but you may not actually get zero.     Now let's compare with the 2892 and see where we might have a discrepancy. First off we have a problem of which one is a using did he use the chronometer grade 1 or the top grade or what?  None is basically just much tighter timing tolerances. So when he's using an example watch conceivably might be a chronometer grade watch then things are going to be much more  perfect than what you're going to see.       NH35_TG.pdf ETA 2892-A2 Manufacturing info.pdf
