I recently got done servicing my 7750 movement, and it has been giving me issues. The timeographer reading shows no issues, a little more positional variation than I'd like, but otherwise getting around +8 seconds a day. However, with the hands on, it seems to be loosing 5 minutes an hour, sporadically. I replaced the mainspring when I serviced it, I don't know if that's the issue, or what it could be. Could the canon pinion need tightening? Or should I do a complete tear down again and start over?
Any ideas are great help!
Thanks!
It has occured to me that this could be a loose cannon pinion, and probably is, considering how smoothly the hands move. Any advice on how to tighten one properly on a staking set? Sadly I don't have a pin vise.
If you have no cannon pinion tighter then I highly recommend this.
Although pricey it's versatile fitting all canon pinion sizes and the most important thing control.
I have some special anvils that fit to my Seitz jeweling tool which I use because of the control issue.
If you sneeze the cannon to much your in a host of trouble.
This is not a tool for use with the 7750. There is an indirect cannon pinion driver that has a slipping clutch, if this is slipping, I suspect it will have to be replaced. Here is a picture of it from Lawson's post.
Good reminder Geo should have remembered this set up for the 7750. This is the part that also needs a good lube because if it is seized other problems happen
Agreed - the lube required for the correct friction is 9501
Do not tighten the floating canon pinion (the one under the hour wheel) - it is supposed to be loose.
The floating canon pinion is loose, and I lubricated the offset canon pinion properly, and made sure it was not slipping on the post, however it is losing time like crazy, still. It is registering perfect on the timeographer, but is showing a few minutes lost an hour! I'm at my wit's end. This is the third complete teardown of this movement.  :pulling-hair-out:
This is a strange one. The symptoms certainly point to slippage, and the prime candidate would be the cannon pinion as previously mentioned.
You say that it was definitely not slipping on the post which is correct, but did you check for slippage between the triangular clutch plate and the outer gear? If that is also OK, it sounds like there must be something binding after the cannon pinion causing the pinion to slip because of the increased drive force required. If this was the case I would have expected that to show up as an issue on the timegrapher.
I agree with Geo binding or slipping somewhere.
Example I had a Seiko that ran perfect on the timographer but when cased would not run after a lot of fiddling and many post here found that a previous repairer had fitted the wrong crystal & it was binding on the hands. Might be worth looking at these areas hands etc.
Does it show the time lost on the timegrapher with the hands and dial on, and time properly with them off?
If so, the issue is not with the movement, it's in the fitting of those items.  Here's a few troubleshooting items to look at:
1. Check that the dial feet are not bent.  This can cause the dial to seat off-center and rub on either the pinion or the hands.
    Make sure each of the four holes in the dial are perfectly centered around each post for the hands.
2. Check that all hands clear the dial and the other hands ... especially the subsidiary seconds hand ( @ 9 o'clock) is not touching the dial.
3. Check the hands are not contacting the glass.
Hope this helps.
Timeographer reading is perfect whether dial/hands are on or off. No sub seconds on this movement, however the hour and minute posts are slightly offcenter, not sure how to adjust a 7750 post to center them.
If the posts are off centre then you might have a re-dial i.e. the dial is not the original & is not exactly the correct fit. If it is not binding on the hands and gives good readings on the Timographer in all positions when cased up I am to be honest at a loss. The fault is happening when the watch is being moved not static which would indicate a balance issue. When you change positions on the Timographer does it settle down quickly or does take awhile before it settles.
By any chance are the cap jewels in the correct way around i.e. the concave shape should face the balance staff. Just a thought.
    • Bad news: Longines doesn't provide this service free of charge any longer. I have to ask for an extract from the archives or a certificate of authenticity, but I'm afraid it's not worth the cost for this watch. Too bad 🥴
    • Tool for removing or pressing the bezel? Most likely you have to remove the bezel (with a knife) before removing old crystal or inserting a new one. You can press the bezel with the crystal press if you have a suitable die with straight walls or otherwise a die that has enough clearance that it doesn't touch the crystal when pressing the bezel.
    • This will be my first crystal replacement, I have a press, but looking at the watch I wonder if I might need a bezel tool also. Any and all help appreciated.
    • I'm not entirely sure you fully understand what he's doing in the video. For one thing he's giving examples of things like about 16 minutes he talks about opening up the regulator just a little bit. Opening up the regulator slows the watch down to compensate for that he moves the regulator fast and now it's keeping time again but the regulator pins are too far apart. I have an image down below on top of it shows the effect of regulator pins and amplitude. If the regulator pins are farther apart than the example down below then at a higher amplitude timekeeping will be much worse. Why the regulator pins are supposed to be adjusted as an average rule approximately twice the thickness of the mainspring itself. In other words if you look at the spacing it have one half of the hairspring thickness on either side of the hairspring itself. There is like he talks about the video a little bit of adjustment here and there. So in his example where he opened them up it will really dramatically screw up timekeeping based on amplitude. Then when you get to the 20 some minutes like you say he is adjusting the regulator pins closer together to get a more even timekeeping based on amplitude and amplitude changes are caused by going to various positions. Then and the other example of the image down below regulator pins too far apart and they hairspring is not centered and look what that does the timekeeping. So hairspring is supposed to be centered regulator pins are supposed to properly spaced. Then you get reasonably even timekeeping like it shows in the upper image. It's not like we're regulating out positional errors like poising errors because that's something entirely different.   In the part number above and in the video both of you left off details. I which version of either of your watches I will just make you's timing specifications for your watch down below may specify how you're supposed to do it other words you wind up the watch fully wound up you wait 10 to 60 minutes in the four positions it should be within 60 seconds. Yes it can be closer but you may not actually get zero.     Now let's compare with the 2892 and see where we might have a discrepancy. First off we have a problem of which one is a using did he use the chronometer grade 1 or the top grade or what?  None is basically just much tighter timing tolerances. So when he's using an example watch conceivably might be a chronometer grade watch then things are going to be much more  perfect than what you're going to see.       NH35_TG.pdf ETA 2892-A2 Manufacturing info.pdf
