I search and got zero results so here I am.  Which is better? I have a small ultrosonic cleaner that my wife uses for jewelry.  Can I clean with water and some of her jewelry cleaner?
Thanks.  Larry
Have a read below
Edited by jdm
I did a search and received 35 pages of results...
https://www.watchrepairtalk.com/search/?q=lighter fluid&quick=1&type=forums_topic
I suspect you used the search box within a sub-forum which will not yield so many results as they are relatively new. Best to search from the front page (index page) of this website and you will get the most results, or choose from the drop-down options within the search box to search "Everywhere" rather than "This Forum".
I hope this helps.
Thank you Mark.  I am such a new bee that I did not search for IPA as an abbreviation for isopropyl alcohol. (The search for IPA brought many hits)  I only knew IPA as India Pale Ale. I will try to not be such a headache in the future.
By the way I am truley enjoying your lessons.  I need to do fault finding over, at least a few times to get it down.
Thank you for all the work you do for us.
Larry (Midazolam)
