Missing Spring?
RogerH
So, a friend has bought a nice looking 1930s German wall clock. The standard R&A Vienna style. He asked me to get it going but when I went to fit the pendulum there was no suspension spring. I only managed a few pics but am I missing something? I can't see how this clock would work without a pendulum but no idea how it would fit. Hopefully he'll bring it round so I can have proper look but any thoughts would be much appreciated.
Hi  The fact that it has a crutch confirms the point that it should have a pendulum and suspension but looking at the escapement pictures where it fits is an other thing. need a few more pics of the escapement block and fittings, and one of the clock front.  A check on th front for a makers mark.
You are missing the block that screws onto the balance cock. Does the dial have a little hole above the 12 on the dial because if it has then it will be a Brocot suspension block. See photos, if not it will still be like the photo but not with the long adjuster.
I've never seen screws like the ones holding the movement together before.  Any chance the pendulum is carried in another section of the clock and the movement just racks in aligning on those screws.  It also has a very generously relieved crutch.  Possibly for better alignment of two parts that you may not have a hand on at the time of installation.  That would also reduce the possibility of damaging it or unintentionally affecting its rate.
Just spit ballin.
Shane
  • 1 year later...
I just picked up a clock with an identical movement at an antique store in France.  I puzzled over the same issue. I think that Shane above is correct. My clock is missing the suspension spring, but the movement works perfectly.  The movement slips into the wooden case and is held by a brass bracket. At the top of the bracket is a protrusion that has both a slit  and a small hole for a pin.  The pendulum would seem to fit perfectly with a small suspension spring (which I don’t have yet) that fits into the slit in that protrusion. When the movement is attached to the bracket, the crutch should align with the pendulum.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
