Dipping Watch Parts in Oxalic Acid - Does Anyone Have Any Experience?
Hello Everyone,
I will be picking up some Oxalic Acid tomorrow so I can perform some experiments on rusted steel in support of my upcoming paper Why (and How) We Clean Things.
Does anyone have any experience with Oxalic Acid?  I am open to tutelage in terms of general materials handling (the stuff is pretty strong) and especially interested in how it might be used to clean steel watch parts.
My intention is to use Oxalic Acid to remove rust from the end-stage Winding Work parts:
- Crown Wheel(s)
- Barrel Ratchet Wheel(s)
- Ratchet Wheel Pawl ("click")
Am I crazy to do this?  How crazy?  Why?
g.
I picked up a 5Kg tub of oxalic acid earlier this year after watching some YT videos on how wonderful it is. But after some experimenting, I don't find it very effective.
I tried removing rust stains from cloth, removing rust from screws, yoke springs, lime scale around the taps, etc. And I wasn't impressed.
Previously, I used hydrocloric acid, phosphoric acid and citric acid for rust removal. All of these work better than oxalic acid but are more prone to creating pitting of the surface. I also tried a 50/50 mix of citric/oxalic acid. This seems to work best.
Let us know your experience when your oxalic acid arrives
Hello @HectorLooi,
Do you remember what concentration and duration you worked with?
I too am interested in the other options, and especially in phosphoric acid because of the conversion as opposed to loss factor - but I'm starting with a oxalic because it's the first one I could source easily.  Your list and my list of acids is pretty much the same, though I would also add acetic acid to the list because it's so safe to handle in typical solution(s) like white vinegar.
g.
I use a shop-mixed clock cleaner that was developed at the Finnish watchmaking school that uses some oxalic acid in it. I've mentioned it before but the recipe is:
1 liter 99% isopopyl alcohol
3 liters distilled water
50g oxalic acid
60g oleic acid
approximately 80g of 24% ammonia
To mix, heat the alcohol until very warm in a big pot, add oxalic and oleic acid and mix well, add the water, the solution goes all cloudy. Add the ammonia, slowly, stirring, until the solution turns clear, that's the right amount of ammonia. It's a rather abrupt change. At this point the ammonia has combined with the oleic acid to form a soap.
I haven't really noticed that this solution removes rust, but I imagine the oxalic is in there as a boost and maybe helps clean oxidation a bit. I've tried it at at stronger concentration, like 30g in 1 liter of water, and it does de-rust, but not like other acids. But, it does seem gentler to the underlying steel like Hector observed. One issue I have with using acids on steel for rust removal is hydrogen embrittlement. I don't know all the facts and science behind it, just that it is an issue and I don't want issues down the road, so I tend to do only mechanical rust removal.
7 hours ago, Gramham said:
Hello Everyone,
- Crown Wheel(s)
g.
I did a little research and a post a while ago on rust removal and did come across oxalic acid. Personally i didn't think it worth a mention as there are much more readily available alternatives that do a fantasic job. The acetic acid in vinegar works extremely well. The water content did concern me but as long as the parts are thoughly and quickly dried its not an issue.
https://www.google.com/m?q=washing+soda+rust+removal&client=ms-opera-mobile&channel=new&espv=1
I've used this process about 20-25 years ago for cleaning a very rusty antique engine block before rebuilding it.  It worked great.  I didn't notice a significant loss of the base material or pitting but since it was all done before any machine work my standards were low.  I was concerned about hydrogen embrittlment but that's mostly a concern with harder alloys having a tighter grain structure.  From what I remember, the atomic hydrogen can get into the steel recombines into diatomic hydrogen and can't get back out and acts like an anit aggregate.  I also used this method more recently for prepping a set of wheels for my four wheel drive truck.  Still concerned and since the stakes are higher, I limited the duration and cleaned more of them manually.
Good luck and keep us all informed.
Shane
No. I just put half a tsp of each into jam jar filled it with enough water to dissolve it. It was probably quite concentrated.
I sometimes mix dry citric acid, oxalic acid and scouring powder and add a little water to make a paste for scrubbing out stubborn dirt around the house, like soap scum in the shower, calcium deposits around the base of the taps, etc.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
