National Electric Watch Cleaning Machine
hmmm…this one’s stubborn, innit? You don't describe your technique- if you didn’t do this, try the following: set the lift on it’s end- that’s why it’s shaped that way! Next, opening the jaws all the way sometimes evens out the teeth. Then close so the teeth are slightly narrower than the crystal, carefully place the watch on top and slowly open the jaws until the crystal drops in the jaws while the case edge rests on top of them. Make sure the watch is flat and carefully tighten the jaws. Yes, it may become very tight and you may break the crystal. One of the few things that’s replaceable and considered a consumable in most cases…
That's a sensible policy, if the wheels are available, but they are becoming hard/impossible to find.
It only takes me a minute or two using wet and dry then Polywatch to polish a crystal, I don't see the need to use a rotary tool. Indeed, the only time I tried to use a rotary tool to polish an acrylic crystal, it was far too aggressive and burnt the acrylic - but that was my old tool with a minimum speed of 10,000 rpm
Tool collection, yes, hording no, I have an aversion to anything not being used. In future, reassemble the movement as far as possible, bag and label what it is and what's missing. -
Welcome to the forum. You don't need the crown to remove the stem as you can just pull it to the 2nd position to access the dimple. Just grip the tube with a pair of pliers and pull it out. Measuring for a replacement could be a little more difficult for a beginner so maybe best just getting an assortment. For the crown you'll need to measure the diameter of the recess where it sits, the outside diameter of the tube along with the thread size of the stem (think it's 0.9mm) Need a closer look at where the crystal meets the case, it looks like what's called an I-Ring and should just push out from the back, preferable with a press. You can then measure the diameter and thickness of the crystal to get a replacement. Not sure what you mean about cleaning and oil solution? Edit Should have asked if you've checked the movement still works?
