Hi guys ive been trying since yesterday to access cousins uk website but all i get is a time out error or that the domain name needs to be renewed by owner ?
Anyone else having problems accessing the cousins site ?
Surely they would have kept up to date with their web info ?
It won't won't work for me either. :(
Glad im not alone, its a real pain. I have tried all devices and different browsers but to no avail. Webchecker says the site is up and running but i can't access it  :pulling-hair-out:
Rogart63 - tried again and still no success :(
I need to order parts for customers but looks like im stuck :(  If anyone else has issues please let me know
Hmm well at least i know im not going mad and my pc is having a fit, if others are having issues then i know its not my end. Hopefully the issue will resolve by monday as i need to order, i will give them a call to let them know there are issues.
Bummer :(
No luck from my end either. They may well be having temporary server issues. Roy's WatchforumUK has had intermittent problems during the last few weeks - it does happen.
I'm getting a "pending renewal or deletion" notification dated 18/6/2015.
Maybe his domain got hacked like Dagaz did a few weeks ago. Lost his domain so had to get a new one.
Well it has come back up for me now, i have no idea what has caused the issues or even if cousins have been aware that it has been going on. I suppose i better order quick before it goes down again :)
Who's "Woking" and what do you want them to do to you? [emoji47] [emoji16] [emoji12]
**BLEEP** iPad spell checker!!! :D
Works for me at 22.57 here in the UK.
Try clearing your cookies from which ever web browser you are using. Some times that will do the trick.
Looks like they forgot to renew their domain name - happened to me before.
They obviously quickly renewed it but it takes time for global DNS to propagate and that is why some of you were seeing the site and others were seeing the Network Solutions parking page.
Domain Name: COUSINSUK.COM
Registrar: NETWORK SOLUTIONS, LLC.
Sponsoring Registrar IANA ID: 2
Whois Server: whois.networksolutions.com
Referral URL: http://networksolutions.com
Name Server: NS.RACKSPACE.COM
Name Server: NS2.RACKSPACE.COM
Status: clientTransferProhibited http://www.icann.org/epp#clientTransferProhibited
Updated Date: 21-jun-2015
What I don't understand is why they did not renew it for the full amount allowable - 10 years. Look - they only renewed it for one further year:
Expiration Date: 18-jun-2016
It's cheap as chips to renew domains these days - probably would have cost them about $80.
Watchrepairtalk.com won't be up for renewal until 2023 :P
    • My drawings are not to scale, BTW. Here is the FreeCAD illustration of what was printed. It has been very helpful to hold the printed bezel in my hand to get a sense of scale. My plan over the next few days is to get some fender washers. They come in a nearly ideal thickness and and OD that is close to what I want. I will make a precision arbor to hold the washer in my lathe to turn the outside dimension.  Still pondering the best strategy for the inside cut.
    • Thanks Mark, I contacted the seller to see if they have any more info on separating the case.
    • Hi all, I've engaged here a couple of times over the years but never introduced myself. I've been restoring vintage timepieces for 15+ years and focus mostly on 1940s-1980s wristwatches. The farther gone it is, the more I enjoy bringing it back to life. Every now and then I come across something uncommon that I want to share that others my find interesting.  Or sometimes I come across a challenge that I haven't run into before, so I enjoy reaching out to others who I can learn from. Best, g2w
    • Very interesting! I answered the mail from Longines, explaining that I was a bit disappointed and that I wouldn't ask for a costly confirmation for a watch which isn't a high-end one ... and I received another email explaining that they couldn't not certify the authenticity of the watch, but they could specify that, according to the serial number on the caliber and to their handwritten records, the watch was produced in 1938. Great! @Mercurial I will take the measurements and will keep you informed. Thank you all. This forum is incredible 👍
    • Good stuff, thanks!!!  I'm going to save it and re-read your post and watch the video again.  I have a few follow-up question:  My understanding is that the spring vibrates or breathes between the the two regulator pins. When the pins are fully open the effective spring length is from the stud and theoretically no rate adjustment can be made by moving the regulator arm. As the pins are closed the spring gets closer to one side of the regulator block but doesn't touch a pin. You can still move the regulator carrier the entire terminal curve without upsetting the coils.  The rate can now be adjusted using the regulator because the effective spring length can be modified.  My question is: Does the hairspring bounce off and touch one of the pins as it breathes? Is that why the effective hairspring length is adjusted by moving the regulator?  And follow-up: How is amplitude affected by the spring between the pins? Does fully open pins, dial up position = max amplitude?  When spring adjusted to 1/2 width still = max amplitude? When I have crown down gravity is pulling the spring against one of the pins and I would expect rate to go up and amplitude to go down. Is that correct?
