What Type Of Polishing Machine Do You Guys Use? A Dremel Or Bench Grinder Polishing Machine? And Why After I Polish, It Becomes Blurry?
Hi, i recently bought a dremel machine and dialux green color compound. But why after i polish, the surface becomes blurry? I was wondering is it because I'm using dremel? And is there anyway way to fix? Thanks a lot.
Edited by number98
I prefer to polish by hand, it keeps edges nice and sharp, but takes a lot longer.
Just curious, what metal are you polishing?
Just normal 316 stainless steel. Oh. May i know what type of compound you use?
A lot of the compounds leave a waxy film & normally require further hand polishing to remove the residue. On stainless steel I use a Dremel with hard felt mop & blue colour final finishing compound, finishing off with a pink colour Selvyt silver cloth. The hard felt mop used carefully will keep the edges sharp. On silver I just use the Selvyt silver cloth & on gold & gold plate I use a bugundy colour Selvyt gold cloth
your motor probably isn't the problem, green dialux is fantastic but keep in mind, like all compounds, it produces different results depending on what wheel you're applying it with, as well as how you're going about it.
in polishing steel I'll generally stick to chamois and fluffy cotton mops, the chamois is a little firmer, it will take out light to moderate surface damage (depending on how persistent you are and hot you run the piece.) and finish up steel to usually a cloudy mirror, sometimes a good mirror, but usually some way cloudy or imperfect.
So I have to switch out to the softer cotton, which needs to be run a good deal faster than the chamois (make no mistake it firms up with speed, so fair warning, it will take off skin if you're careless) But it's softness means it can be used as a final finish with the same compound, taking out the cloudiness and imperfections of the previous stage of polishing.
For greater damage i stock felt and grey dialux, but you have to be careful with this, especially if it's a mini mop like it is for me, and not a bench motor, it goes either way but especially when you can only work on a small area with a mini mop, a mop as hard as felt can very easily distort a piece, leaving dents and ridges that the light reflecting in it warps around and betrays your mistake.
I advise you work backwards, learn how to get a really good final finish, and progressively learn to take out more and more damage without putting your own damage in and still being able to get that same final finish. It's better to lean on and potentially misuse compounds/mops/techniques that are too gentle than to lean on and potentially misuse things that are too harsh.
Edited by Ishima
Hello ishima, thank you for your reply. So after you've switched to a fluffy soft Cotten mop, do you put any compound or you don't? And normally how much compound do you "load" the wheel both the chamois leather and fluffy Cotten mop? I heard somewhere that loading the wheel with too much compound causes the surface to blur too right? I've been using the stock felt mop that came along with the dremel when I bought it. But whenever i polish, it caused the surface to turn blurry despite having literally all the scratches removed. Thanks.
Good questions, the rule of thumb for loading or charging wheels is 'little and often' so usually i stop charging almost as soon as i see the wheel start to turn a little green with the new compound and then after a few passes re charge the wheel, basically this is because polishing and buffing happens when both the compound, and the fibres of the wheel are able to contact the piece, charge a wheel too much and those fibres wont reach the piece, they'll be stuck behind a thick layer of compound.
I do charge my cotton wheel as well, but it's a good idea to have a a 'clean' cotton wheel as well in case you're running into problems in final finishing/cleaning, this is a wheel you don't charge but just use to remove used compound off of the surface of what you're polishing. This is because, sometimes trying to clean off residue can leave marks, usually I find it doesn't, i'll usually clean a piece of with with wet wipes or some spirit (isopropyl alcohol) and tissue/toothbrush and that's usually fine but strictly speaking it's not the way to do it, and on occasion it has left marks. If we were using a bench motor with a large cotton wheel you'd charge one side of it, and move the piece from the charged side to the uncharged side, doing the final polish and cleaning the piece of residue in one motion, but on mini mop that isn't practicable, hence keeping a spare, uncharged cotton mop.
You'll probably need to get a lot of practice in, I found learning refinishing polishing to be immensely frustrating because the people who could do it didn't seem to know how to explain it or would leave key details out, so most of my learning was trial, error and me trying to work out the theory myself, I just hope I've helped you avoid that experience somewhat.
There's this video that get's posted in every thread like this, because it's one of the best videos to explain refurbishing/refinishing, it covers a lot of the stuff I've mentioned, it's about polishing with a bench motor but a lot of it is transferable to hand held motors.
  Edited by Ishima
https://www.youtube.com/watch?v=YMuWrI-sCj8
Hello ishima thank you for your reply! I just bought two chamois leather mop mounted and two fluffy cotton mop mounted from cousinsuk! Yeah. The video you've attached is one of the best video regarding about polishing I've ever seen. I didn't know buffing could remove such a deep dent/scratches. I thought it was not possible. As I normally used sandpaper to sand the dent/deep scratches! Really thank you so much for taking the time to answer my question :)
If you are getting blurry/foggy end result after any compound it means it is ready for a wash. Always thoroughly clean parts after each buff or polish in a degreaser ( fairly liquid will suffice if you have no chrono clean or related cleaners ). The compounds are binded using oils so the film they leave needs to be removed. It really is crucial to clean between each stage, the best results come from patience and knowing your compounds. Just to note there is a big difference between polishing and buffing, they are not one and the same and require different techniques. I could write a book on it but i have nee the time :)
Im much like Geo, i prefer hand polishing using traditional techniques with various oils, woods, burnishers, and fine powders, the results are far superior ( Geo knows what i mean ;) )
Firstly, I use the white compound on the cotton wheel to polish off scratches. There will be swirls left on the surface at this stage.
Then, I use the little felt wheel applied with some 5.0 micron diamond paste to polish off the swirls. But the surface is still a little blurry at this stage.
Now I'll applied some 3.0 micron diamond paste on a new felt bob and buff the surface to near mirror finished.
Final buffing by hand using Cape Cod metal polish to get the sparkling mirror finished. I can see my reflection [emoji2] grinning ear to ear, and sometimes my wife's too as I always showed her the end results.
    • Thanks Mark, I contacted the seller to see if they have any more info on separating the case.
    • Hi all, I've engaged here a couple of times over the years but never introduced myself. I've been restoring vintage timepieces for 15+ years and focus mostly on 1940s-1980s wristwatches. The farther gone it is, the more I enjoy bringing it back to life. Every now and then I come across something uncommon that I want to share that others my find interesting.  Or sometimes I come across a challenge that I haven't run into before, so I enjoy reaching out to others who I can learn from. Best, g2w
    • Very interesting! I answered the mail from Longines, explaining that I was a bit disappointed and that I wouldn't ask for a costly confirmation for a watch which isn't a high-end one ... and I received another email explaining that they couldn't not certify the authenticity of the watch, but they could specify that, according to the serial number on the caliber and to their handwritten records, the watch was produced in 1938. Great! @Mercurial I will take the measurements and will keep you informed. Thank you all. This forum is incredible 👍
    • Good stuff, thanks!!!  I'm going to save it and re-read your post and watch the video again.  I have a few follow-up question:  My understanding is that the spring vibrates or breathes between the the two regulator pins. When the pins are fully open the effective spring length is from the stud and theoretically no rate adjustment can be made by moving the regulator arm. As the pins are closed the spring gets closer to one side of the regulator block but doesn't touch a pin. You can still move the regulator carrier the entire terminal curve without upsetting the coils.  The rate can now be adjusted using the regulator because the effective spring length can be modified.  My question is: Does the hairspring bounce off and touch one of the pins as it breathes? Is that why the effective hairspring length is adjusted by moving the regulator?  And follow-up: How is amplitude affected by the spring between the pins? Does fully open pins, dial up position = max amplitude?  When spring adjusted to 1/2 width still = max amplitude? When I have crown down gravity is pulling the spring against one of the pins and I would expect rate to go up and amplitude to go down. Is that correct?
    • A quick Google for Longines 25.17 found several similar watches - like this one with writing on the case back similar to yours https://benjaminmarcello.nl/product/longines-cal-25-17-tank-from-1938/
