Hamilton Grade 974 size 16s center wheel pillar plate jewel replacement
Similar Content
I’m having a hard time seeing exactly what’s going on, even when I zoom in as much as possible, but it kind of looks like the hairspring has gotten itself tangled up. How does the spring look when you place the balance cock on your balance tack? Tangled?
By luiazazrambo · Posted
