Hi, can anyone help me find name, part number and where I can buy these? They are like plastic washers about 2mm dia x 1mm this that are pressed into the main plate and the dial feet push into them.
any help appreciated.
cheers,
boyd
Hi  What is the caliber and make of the movement these plugs are in. If we can find a parts/tech sheet may be able to help.  They may not even be available as spares, depends on the cost of the movement and maker.    a picture of the complete movement front and back would be helpful
I may be wrong but are the green dial feet retainers are part of the green plastic circuit  board? I would use some G-S hypo cement glue in the damaged area to attach the dial. The glue is easy to remove when servicing.
Thanks, I did end up using g-s hypo. But they are not part of the green circuit board. I stripped the whole thing. It’s running quite well now. Thanks for commenting!
I had a seiko 6530A built on the green plastic frame but the whole thing disintergrated
it's an unfortunate common problems that a lot of plastic with age disintegrates.
I'm attaching the service guide and parts list. I'm not seeing anything that looks like dial feet whatever? There is a possibility this part of the main plate or I'm just not seeing what I'm looking for.
Seiko 93A.pdf
  • 2 months later...
Thanks John, I also couldn’t see the feet.
