Hi, I've just aquired this lovely watch. It seems to be more timekeeping than a quartz!!
My problem is how to open the case. I assume a special tool but any help would be very gratefully recieved.image.png.f58560b755ebab4007e92b335a7de3f0.png
Hi There is usually a key that fits the shape of the back. Be aware not all fancy backs are screw on some are snap on. But try the nut method. superglue a large nut on the back and when secure use a spanner to screw off. The nut can be removed using acetone
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
