Hello everybody.
While restoring/servicing this watch, everything seemed fine. But after I started wearing it, I noticed that the whole movement with the dial was loose in the watch case.
I opened one of my other newer Genève's and noticed that the watch case lid had a tension ring. After a bit of googling, I found out that this model also needs one.
Is it possible someone might know the part number of the ring or where to get one if not original?
Thank you in advance!
Edited by swiss2k
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
