This Speedmaster has no opening lug slots on the back cover.  Ordinarily I would assume it was snap on back but I see no notch for a case knife either.  How to open safely?
Thanks,
- Tim
Same thing on my Speedy Reduced.  Used a watchmaker knife (Rolex, hihi) with a thin blade, put it in the gap carefully, caseback snapped off quite easily.
always nice if you would post pictures so we know exactly what you're talking about. Because it may be that this is a watch that goes out through the front you need to remove the crystal.
Yes!  Sorry 'bout the picture.  Here are two...
Thanks!
That first picture makes it look like there's a notch (for case knife) but there's not.  That's a reflection.
That first picture makes it look like there's a notch (for case knife) but there's not.  That's a reflection.  It is the same gap (or lack thereof) all the way round.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
