Right...... about to start on this, after watch Marks vid twice....... and he says to put the chrono in the start position. The one I am servicing, the chrono is not working, the time is working OK. Therefore I cannot put it in the start position. So do I go in blind and see what's going on in the module? If so, will I be able to reset the hammers on re-assembly.
Any remedies greatly appreciated.....
Keith
Keith the reason to put it in start mode is to release the tension on one of the springs. You should be fine.
Do you need the service sheet?
I thought as much, but thought best to check.
Service sheet would be lovely please. I shall message with Email.... :)
No problem. I will send it when I get on my computer. Watching the new mad max at the moment
  • 10 months later...
    • My drawings are not to scale, BTW. Here is the FreeCAD illustration of what was printed. It has been very helpful to hold the printed bezel in my hand to get a sense of scale. My plan over the next few days is to get some fender washers. They come in a nearly ideal thickness and and OD that is close to what I want. I will make a precision arbor to hold the washer in my lathe to turn the outside dimension.  Still pondering the best strategy for the inside cut.
    • Thanks Mark, I contacted the seller to see if they have any more info on separating the case.
    • Hi all, I've engaged here a couple of times over the years but never introduced myself. I've been restoring vintage timepieces for 15+ years and focus mostly on 1940s-1980s wristwatches. The farther gone it is, the more I enjoy bringing it back to life. Every now and then I come across something uncommon that I want to share that others my find interesting.  Or sometimes I come across a challenge that I haven't run into before, so I enjoy reaching out to others who I can learn from. Best, g2w
    • Very interesting! I answered the mail from Longines, explaining that I was a bit disappointed and that I wouldn't ask for a costly confirmation for a watch which isn't a high-end one ... and I received another email explaining that they couldn't not certify the authenticity of the watch, but they could specify that, according to the serial number on the caliber and to their handwritten records, the watch was produced in 1938. Great! @Mercurial I will take the measurements and will keep you informed. Thank you all. This forum is incredible 👍
    • Good stuff, thanks!!!  I'm going to save it and re-read your post and watch the video again.  I have a few follow-up question:  My understanding is that the spring vibrates or breathes between the the two regulator pins. When the pins are fully open the effective spring length is from the stud and theoretically no rate adjustment can be made by moving the regulator arm. As the pins are closed the spring gets closer to one side of the regulator block but doesn't touch a pin. You can still move the regulator carrier the entire terminal curve without upsetting the coils.  The rate can now be adjusted using the regulator because the effective spring length can be modified.  My question is: Does the hairspring bounce off and touch one of the pins as it breathes? Is that why the effective hairspring length is adjusted by moving the regulator?  And follow-up: How is amplitude affected by the spring between the pins? Does fully open pins, dial up position = max amplitude?  When spring adjusted to 1/2 width still = max amplitude? When I have crown down gravity is pulling the spring against one of the pins and I would expect rate to go up and amplitude to go down. Is that correct?
