Bought this clock at a flea market. Can not find anything about it.
edteach
I tried searching for Vidrio clocks, Vidrio glass, jadeite, and uranium glass clocks. This clock forecloses in ultraviolet light. If anyone knows I have a few questions on this clock. First is who made it? I get nothing on the search for Vidrio clocks but for some slag glass Cadillac clocks. When I bought it it had no cord. I took it apart and put some alligator clips on the wires left inside the clock and I can hear the hum of the coil but no movement. The starter spins free but will not run. any help in how to fix it and information about the clock if anyone knows would be much appreciated. Thanks.
These early synchronous motor clocks were not able to start automatically. The start knob had to be given a quick turn to get the motor running, much like vintage cars with a hand crank.
Your starter knob seems to be broken. I think it would be safer to use a proper connector on the wires before trying to start up the clock. And check for leakage before touching the metal parts
Its repaired. The coil had some broken magnet wire. drilled  out the rivets and unwound it to remove the broken wire and soldered it back together, This is a picture of when I just started to drill out the coil rivets. DSC08040.JPG.f7d84972c07c3351d87d3cd0713ae22e.JPG
Video of the clock working now. https://studio.youtube.com/video/8mSmDAY5CS8/edit
Edited by edteach
  • 2 years later...
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
    • Nailed it Andy 👍 It kinda was, but had a happy ending all the same.
