Well I found this site looking for a stem for a font 96 movement.   The prospect of making one was a bit overwhelming   and I was having no luck crossing it over.   I am really hopeful.  If this turns out they will be a wonderful resource I will keep everyone updated.   http://www.windingstems.com/ebosa.php
Sincerely,
Jim
A very nice find. As you know I'm no longer in the business. My question, is it becoming harder to find parts for the good old wind ups and the auto's because back in my time I had very little trouble in obtaining parts.
Hippy - it's a nightmare tracking down some parts. Maybe a good sticky on here would be people's best sources - for those who are prepared to share. Add to that a list of sources for technical documentation which can also be tricky.
Clockboy - the last stem I had from them came to the UK in a couple of days. They also list on eBay under the name vacheron_nl.
Stuart
Update     Two weeks I received the parts from the UK   fast standard shipping.  I will update on the fit  they look good   :-)
Sincerely,
Jim
Edited by Jim
  • 4 years later...
Stuart
No; this is not the same; we are 2 different companies.
Quote
No; this is not the same; windingstems.com is not mine.
Regards,
Albertine (Vacheron_nl on ebay)
  • Similar Content
    • My drawings are not to scale, BTW. Here is the FreeCAD illustration of what was printed. It has been very helpful to hold the printed bezel in my hand to get a sense of scale. My plan over the next few days is to get some fender washers. They come in a nearly ideal thickness and and OD that is close to what I want. I will make a precision arbor to hold the washer in my lathe to turn the outside dimension.  Still pondering the best strategy for the inside cut.
    • Thanks Mark, I contacted the seller to see if they have any more info on separating the case.
    • Hi all, I've engaged here a couple of times over the years but never introduced myself. I've been restoring vintage timepieces for 15+ years and focus mostly on 1940s-1980s wristwatches. The farther gone it is, the more I enjoy bringing it back to life. Every now and then I come across something uncommon that I want to share that others my find interesting.  Or sometimes I come across a challenge that I haven't run into before, so I enjoy reaching out to others who I can learn from. Best, g2w
    • Very interesting! I answered the mail from Longines, explaining that I was a bit disappointed and that I wouldn't ask for a costly confirmation for a watch which isn't a high-end one ... and I received another email explaining that they couldn't not certify the authenticity of the watch, but they could specify that, according to the serial number on the caliber and to their handwritten records, the watch was produced in 1938. Great! @Mercurial I will take the measurements and will keep you informed. Thank you all. This forum is incredible 👍
    • Good stuff, thanks!!!  I'm going to save it and re-read your post and watch the video again.  I have a few follow-up question:  My understanding is that the spring vibrates or breathes between the the two regulator pins. When the pins are fully open the effective spring length is from the stud and theoretically no rate adjustment can be made by moving the regulator arm. As the pins are closed the spring gets closer to one side of the regulator block but doesn't touch a pin. You can still move the regulator carrier the entire terminal curve without upsetting the coils.  The rate can now be adjusted using the regulator because the effective spring length can be modified.  My question is: Does the hairspring bounce off and touch one of the pins as it breathes? Is that why the effective hairspring length is adjusted by moving the regulator?  And follow-up: How is amplitude affected by the spring between the pins? Does fully open pins, dial up position = max amplitude?  When spring adjusted to 1/2 width still = max amplitude? When I have crown down gravity is pulling the spring against one of the pins and I would expect rate to go up and amplitude to go down. Is that correct?
