Hello, I am new to this forum.  I am an avid collector and watch repair hobbyist.
I have an Elgin Chevron direct read / jump hour which I am repairing and I need an hour dial.  The paint on the dial I have is peeling off.
if you have an idea of someone who may have a dial please let me know.
Thank you for your help.
Denzil
pictures are always nice so we know exactly what you're talking about. for instance I was thinking a pocket watch until I did a search on the Internet. Yes they did bake pocket watches with indicator discs.
then for those not familiar here's a link to pictures
https://www.vintagehamilton.com/store/p1458/Lord_Elgin_Direct_Read_Chevron_Jump_Hour.html
then I'll send an inquiry to somebody who's greater knowledge than I have on Elgin watches and see what kind of an answer we get back. Usually on anything of vintage it's really hard to get parts but that isn't as vintage is a pocket watch. The other way as you perhaps can find a dial refinishing company who could refinish or make you a new disc perhaps
Edited by JohnR725
you're options are
1. stalk fleabay for a movement or a roasted doner with a good disc (expect to pay out at least 100 on a very good day to 300 on a bad day)
2. dial refinishes can redo the hour disc
thats about it.
the minute plastic disc is reproduced and can be found on fleabay easily enough.
13 hours ago, diveboy said:
you're options are
thats about it.
Thank you for your response.  I have been searching eBay and Etsy and other parts houses but haven’t been able to find the hour disc.  I contacted a number of dial refinishers and none of them have this dial set up to produce.
Denzil
you're options are
thats about it.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
