The local chapter of NAWCC jointly with CAWCG (affiliate of AWCI) held a class on staking and jeweling today...just 30 minutes away!
It was great.  I had never used my Seitz jeweling tool for anything other than tightening a cannon pinion.  It was fun...and a new vista!!
Great bunch of guys too.
  • Like 10
Would you be able to reveal what you learnt at the course? Curious what else you can use a jeweling tool for: as far as I know, you can use it for jeweling, reaming holes, tightening cannon pinion, and installing hands.
Edited by ifibrin
Nothing beyond that. I had used mine for cannon pinions, but had never removed a jewel, reamed a hole, replaced a jewel. So, it was useful to practice this with knowledgeable instructors around.
Edited by LittleWatchShop
On 10/29/2022 at 4:50 PM, LittleWatchShop said:
CAWCG
I was curious and is looking at the website below looks like you have in AWCI chapter somewhere in the tiny state of Texas. Quite amusing though is when you see the Texas chapter listed in a click the title to go to the website it's a bit interesting isn't it?
https://www.awci.com/member-center/affiliate-chapters/
then are they doing this kind of thing often and do they have chapter meetings on a regular basis?
Not sure what is interesting other than that there are so fee states represented.
Both the NAWCC and CAWCG groups meet monthly on different days. The NAWCC tilts toward clocks and the CAWCG tilts toward watches.
I learned that watchmaking is taught in Paris............Texas!
At Paris Junior College.
1 hour ago, dadistic said:
If you click through to the website, it's all about snoring
yes I noticed the same thing the CAWCG groups doesn't seem to be a very active group at all.
The reason I asked was just to remind people that there are opportunities depending upon where you live for meeting people with similar interests you.
so for instance national Association of watch and clock collectors has chapters all across the planet. Conceivably one near you
https://www.nawcc.org/local-chapters/
then the American watching clockmakers Institute still has a few chapters left. They used to have considerably more but they've slowly either left the Association like the one in the state of Washington did or just to disappear. leaving the Association meant that in the case of the one in my state we just went independent.
then for anyone in the state of Washington here's where you can go and have meetings and yes they do have classes occasionally
http://www.norwestschoolofhorology.com/wwca/index.html
oh and in case you need more education Texas still has two schools teaching watch repair. There are still quite a few schools in the US not as many as they once were and Texas has two schools. Then at the link below you have to scroll down quite a ways to get the Texas but as you can see them a whole bunch of different branches around the planet.
https://www.richemont.com/en/home/about-us/our-schools/
I also learned that I should take a look at my tools before getting in the car.
I have two Seitz jewelers.  One is 3mm and the other is 4mm.  Turns out that my 3mm is a complete set and the 4mm is incomplete, so I took the 3mm set...BUT BUT...I grabbed the 4mm staking tool.
Happily, the instructors loaned me a tool so I could do the exercise.
Now back home, I notice that my 3mm set has a "Reduction ring" which appears to be purposed to convert the 3mm stumps to 4mm base.
Alas...I could have used the set I took after all.
So...what is the deal with Seitz and the two different stump sizes?
Could you take a picture of the reduction ring? I’ve never heard of Seitz tools coming with such an accessory.
I think the older Seitz jeweling tools USED to come with 3mm pushers in the PAST, until they switched to 4mm pushers, same as the anvils.
Sure, I will do that tomorrow...don’t hesitate to remind me.
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
    • Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance.
    • Ah ok thanks , i see thing differently now. Won't that catch the wheel rim though ?
