Hi all,
I’m working on building a watch with a screw down crown and an NH35 movement.
The screw down crown assembly does not have a spring mechanism, so Im concerned about getting the length correct so the crown will screw down correctly but also not put a load on the movement, and then of course unscrew and allow winding, setting.
Any tricks for doing this? I’ve never done a screw down crown before.
Thanks for any help with this,
Bill
So no one here knows how to do this eh? Ok.
thanks anyway.
I did figure out that the crown assembly is spring loaded, and then I cut the stem too short. Got more ordered and I’ll get right next try.
Sorry for the silence. I guess everybody assumed that somebody else would answer.
I guess the "measure twice, cut once" advice would be a little late now.
The watch should be place in the winding position and the stem cut until the crown is able to wind without engaging the screw down threads. It's better to err on safe side and cut less initially and slowly adjust to the correct length.
Good luck on your second attempt.
If it's spring loaded, it's just a "normal fitting" ?
What I'd do, is make sure the crown is screwed on fully, and the stem pushed in. Then using callipers, measure the distance shown - you don't need the number, just leave the callipers at that setting.
Then holding the stem in a pin vice, remove the crown and measure, from the end of the stem, the amount to remove using the callipers. Mark with a felt pen, then cut and file (to slightly longer at first), and try the fit.
When happy with the fit, Loctite the crown.
SEE CORRECTION BELOW
Edited by mikepilk
Maybe it's too early in the morning.... but if you measure and cut it according to the photo above, it'll end up too short.
It should be measured from the end of the case tube to the bottom of the crown.
Morning HectorLooi, its 7am Now in Uk. Might that mean the bottom of the crown doesnt reach the case ? Depending on how much the tube is protruding.
I think you are right. It was late (and wine was involved), and I wasn't thinking about the spring loaded crown.
You want the bottom of the crown to sit flush with the end of the tube, then push in the spring loaded crown to screw tight.
Edited by mikepilk
This is exactly what I did, and it came out too short. I probably just cut it so close to the mark that when I filed it down it made it shorter than needed.
thanks for the help guys.
We learn from our mistakes, and I've made plenty, which is why I've improved so much 😄
At least parts are available and not expensive. You can buy stem extenders if you cut one too short and can't find a replacement.
I still think you were  right the first time mike, so not so early or drank too much. Stem fully pushed home, the crown wound on fully. This is how it would be when the watch is running and on your wrist, the stem cant be any further in nor can the crown. Then the measurement taken from the case to the crown edge. Take this measurement from the stem end plus add a little back to allow for error in cutting and adjustment.
You are right @Neverenoughwatches. I misread the OP and thought the crown did have a spring.
As these movements cannot be manually wound, you only need to be able to pull out the crown for setting.
(I'll shut up now to stop more confusion 🙄 )
Edited by mikepilk
Definitely worth having them in your parts stash as a backup  Mike
How is it possible to have a screw in crown without a spring loaded crown? I am confused.
I've not worked on a NH35 before. Without a spring loaded crown, how would the winding stem collapse in without breaking?
The only non spring loaded screw down crowns I've seen are Russian Amfibia and Komandirskie. And these are limp and flop around when the crowns are screwed out.
Haha. Its fine Mike, you just need that Yorkshire full English for brekkie.
They are fun to set the time, apparently to prevent damage to the stem adjusting time, date while on the wrist.
The crown did indeed have a spring assembly, it was just stuck and I didn’t push hard enough to break it loose at first.
I finely did get a stem cut correctly and it now works great.
Here’s a photo of the finished watch.
Thanks for the help everyone.
Yes, I  let you discover it for yourself. If you read my earlier post, it is impossible to screw in the crown unless there is some way for it to collapse down without crushing the stem.
Good job!
Thanks H, my original post was pointing out that I was concerned about damaging the movement. It didn’t make any sense to me that the crown couldn’t collapse.
lessons learned on our own are usually the ones that stick.
Thanks again everyone.
    • Why now Mark ?  And which contact has brought you here ? People have been trying for bloody months to get hold of you for reassurance. Shite way to run a forum tbh. Seven months since you last visited. I think we all need to have a long discussion with you about what happens if anything happens to you. Please look forward to lots of questions.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
