This is one of my favorites in my collection, and I have looked far and wide for someone to fix it. There are lots of service centers that can do the work but no one has parts.  I had the movement replaced once before but guess it didn’t take. Sent it to Luminox’s service center they put 3 batteries in said it kept shorting out and needs movement replaced again. I would appreciate it if anyone could either point me in the direction of someone who can fix it for me or where I can get the parts.   Thanks in advance for any help.
I don't quite understand the problem here? in other words you sent it to Luminox they're telling you need to new movement just let them put a new movement in?
Then in order for us to help we need to know what the movement number is.
They don’t have the parts and the numerous other repair centers I have contacted don’t either.
I’ve attached a pic of the numbers off the back of the case.
apparently this version (digital/analog) was made in much smaller numbers than the analog version of the sr-71 Edition and no one I have contacted has the parts.
the unfortunate problem with some watches made much worse if the watch has electrical components is if there is an issue your basically screwed.  unfortunately we do not get a movement number from the back I did find this link which does suggest a movement number ISA 9011. then I'm finding basically no information on the movement at all. So that's the problem unfortunately with rare timepieces is getting components will be impossible. This means of you really want the watch to run again you basically will have to purchase another watch.
https://www.mywatchmart.com/listing/61905-fs-very-rare-luminox-sr-71-9040-blackbird/
