Hi all of you,
I was about to put an ad in order to sell a few balance wheels, but I realized i didn't know how to protect them in case I would have to send them. Would anyone have an idea? It's so fragile because of the hairspring!
Hi   If you have not got the boxes I have seen the correct box I have seen empty ones sold on ebay. Albeit without the correct name on the box , but these can be re-labled. The alternative is to use polystyrene with a punch out for the hairspring
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
