Absolutely baffled by setting issue in 7s26...
58 minutes ago, mikepilk said:
I couldn't see anything wrong in your videos - it all looks to be working OK
Were you just mis-understanding how the cannon pinion works ?
Without the pallet fork in, there is enough friction between the cannon pinion and hour wheel to turn the whole gear train. With the fork in, the gear train is effectively locked, and the cannon pinion should slip on the hour wheel to allow hand setting.
I was misunderstanding and yeah i did not know what you just said. once i put the pallet fork in it all worked. I actuallpy assumed the inside of the cannon pinion and center wheel barely touched, i never realized how much friction they have. It's a really clever bit of engineering!
My original center wheel as my instincts told me WAS bent, i can see it clearly now that i see that the seconds wheel is dead center in the middle of the new donor center wheel which is dead center in the middle of the cannon pinion. In the original one the second wheel was not centered and it was REAL hard to get that cannon pinion over the center wheel and they were bound so tight it would have broken the pallet fork before the cannon pinion could have rotated freely.
That said i now got two working movements! I haven't done the 24 hour run on my second service but using the same balance from the previous one the amplitude is EVEN HIGHER at 288! Thrilled with that!
The problem is that i put my only other balance that looked...ok but not perfect in the first movement i serviced which was getting an amplitude of 272, with the new balance it's getting only about 200. I'm going to try re oiling the top jewel on the balance and see if htat helps but I got a feeling the hairspring needs a little reshaping.
Wtf is up with seiko hairsprings? I got 4 balances with hairsprings that aren't bent but need to be reshaped just a little to get them centered and working properly. I think ALL of them are from 7s26b movements.
I think Gert mentioned something about dodgy hairsprings on 7s26 b movements. They cheap, costs more to get a basic car valet these days, and thats by little freddy from the next street borrowing his mums Henri hoover and a pair of his big sisters knickers to polish your dashboard down with.
Can you check freddy's availability for next week, my car is filthy
Will do. Hes out of little offenders for auto theft today , he likes some tunes on so if you can leave your keys in the ignition for him that would be great.
7 hours ago, thor447 said:
Next in line after @lexacat!!!  I wonder if there is a travel charge going between UK, Australia, and USA?
He said it depends on the market price of your car.
  • Haha 3
On 11/29/2022 at 8:12 AM, mikepilk said:
Glad you got it sorted out in the end.
You have done very well - I have a Seiko 7S26 and can't get it above 240° ! Some Seiko's are like that.
(Next time I clean it I'll see if I can move the pallet jewels in a touch).
thanks. I"m pretty proud of myself. Both of my first services over 270...most of the time. getting 288 on one, and 271 on the other, though it's about 265 ish some of the time. i think it gets that 270 only at full wind.
EIther way, This all turned out better than i thought it would.
  • 3 months later...
It’s a tall order for a first watch but it looks like you nailed it. Can I suggest you try a Sekonda for your next watch? A manual wind would be perfect.
The thing with Seiko is they are very good for learning Seiko but a Sekonda mimics Swiss movements so it will give you a better grounding. Also some of the Seiko jewel shock springs are a nightmare. Get some confidence with the Incabloc ones first
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
