6 minutes ago, HectorLooi said:
SG$ 2.06  39%OFF | 360pcs 6mm-23mm Watch Band Link Cotter Pin Stainless Steel Watch Bracelet Strap Link Pins Cotter Bar Assortment Watch Repair Acc
https://a.aliexpress.com/_mqVcQB0
Try AliExpress.
Hey, thank you for putting in the effort to try and help me.
I did see this listing in Aliexpress before, however I am kind of scared that the pins will not fit my watch. The reason being is that the open end of the pins on the Aliexpress listing, just seem too big to me and I know it's written that their diameter is 0.9mm but they seem quite bulkier in the photos. I don't know whether that is because of the zoom or the camera they used.
I am a complete newbie in watch repair, I would really really appreciate your opinion on this.
I also have been offered to purchase the exact same pins from here:
https://www.cousinsuk.com/product/0090mm-split-pins-by-size?code=P7890P
One more thing that concerns me too, is if 0.9mm will do the job, what if my actual size is 1.0mm, will that matter?
9 hours ago, tomh207 said:
They should look bigger, the old ones over time the head deforms and starts to fall out of the bracelet.
Tom
Thank you a lot for your help!
You really need a more accurate way to measure the diameter. If the size you need is 1.0mm, then a 0.9mm pin will not do. Get your hands on a cheap set of calipers or a micrometer.
This difference will make a difference.  The effort to measure exactly is worth it as a link fail may cost you the watch.
Indeed, have had to do a fair amount of bracelet and case cleanup when an old pin has failed and the watch hit the deck. When I come across pins like these I replace all of them in the bracelet now, too much chance of another one failing.
Tom
@whph4evri dug this out to help you with measuring to ensure you get the correct ones
Tom
