How to remove pressed on wheel? Specific tool?
1 hour ago, rossjackson01 said:
Kalle on Chronoglide showed a way for removing such wheels. He said he was shown it by his original tutor who never used any tool.  Using two pieces of peg wood, ease the tips under the wheel centre and rotate the wheel with small movements, applying gentle pressure toward the centre. He said it always works.
I tried this on three pressure fit wheels that were tight. I cannot afford the Presto tool. Each took over 4 minutes, but it did work, and no distortion to the wheels.
What he said is that he uses the Presto tool for time saving. He presto, it's off.
Can you remember which video, I'll look it up.
56 minutes ago, RichardHarris123 said:
I give up!!! Back to the lump hammer and blunt wood chisel.
Have you ever thought of explosives? Occasionally at work I ask if I can get some C-4 or perhaps primer cord and as of yet none of that has materialized. Although I wasn't actually thinking of using it for disassembly purposes well kind of I was more thinking of making a problem go away permanently. But that might be considered inappropriate and probably some custard be unhappy. Although conceivably I might be very happy of some of the watches were to disintegrate permanently but we do not take watchmakers happiness into consideration in things
ohn. You highlighted as quote "He said he was shown it by his original tutor who never used any tool." Sorry if I gave the wrong information. If I can expand. What he said was that the tutor preferred not to use the Presto tool, but to do it the peg wood way. The tutor taught his pupils whilst never using the presto tool. I am sure he used many other tools. Hence Kalles expertise.
The end up with interesting situations. Perhaps the original person found the Presto tool Not working. As you'll notice there are actually two separate tools so conceivably they had the wrong one. But as I also conveyed their other tools and finding the other tools are challenging if you don't know they exist.
Then a creative souls might work out other ways to do the task. This then of course brings up the problem of?
We end up with a interesting problem of if somebody has a bad experience with a Tool does that make the tool bad for ever for everyone in the universe?
So yes we do get interesting problems and watch repair we seem to have lots and lots and lots of different ways lots of different opinions lots of just everything. With the unfortunate reality of anything in life is there is no 100% this is the way to do it or else. Although that can conflict with some of the views on this group Who do seem to believe in Absolutes.
Hehe.
Scott. Been looking on Chronoglide. He does two 'live' a week. I think it was two weeks ago. But I'm not sure of the movement he was working on. Maybe it is not posted yet. when I come across it I will let you know.
Quite a few of the members watch 'live' as I do. Maybe one of them could remember?
Ross
22 hours ago, Waggy said:
Let me known what you think.
The aliexpress's levers look long enough to work, but I think the tip of the lever is too thick to get under the wheel, with some simple filing and polishing it would work. My point of using a pair of levers is that the tip need to be extra long and equally thin so it would reach the center part of the wheel without bending it up, that's why my first photo shows the side view of the levers. The aliexpress one would bend the wheel up before it could ever reach the prying point. I remember had to keep thinning the tip down multiple times until I can get mine to work.
7 hours ago, HectorLooi said:
https://youtu.be/pDv8KDzfWlo?si=f3HCzwfYfvXyNfzT
Alex shows how to to make your own pair of lifters for the freewheel.
I use the Bergeon 6016 two pronged tool, but you have to be careful not to bend the pivot or scratch the movement. But I like Alex's idea of making lifters out of brass tube. Easy and cheap to make. I'll try that next time.
42 minutes ago, Waggy said:
That's what I broke the pivot with, my fault as I tried to do it in the movement (couldn't release the winding stem) so was doing it at an angle.
Alex's brass rod with a cutout to make a pair of stumpy lifters looks like a good idea. Something to make this afty, maybe a small radius opposite the lifting lip would add to it.
I dont understand how the 6016 works, how does it lift evenly if its tapered ?
It looked like a wedge but appeaes to be two pins that flank the pivot. I suppose because the pins are so long you get even leverage on the wheel even though force is concentrated on the handle side…
WIth the Bergeon 6016, you slide it under the wheel, then twist the handle, and the two blades tilt, effectively rising in height, bringing the wheel with it. I have one, and never seem to find a wheel the blades actually fit under. I use the Presto tool. Those work great, only gripe is it would be nice to have a stop, as on a tight wheel, when it lets go, sometimes it comes up quite violently occasionally bending the wheel. Always been able to straighten them though.
1.2mm seems to thick to fit under a sweep wheel.
1 minute ago, mikepilk said:
That's near the handle. The tips are about 0.1mm
Thank for clearing that up mike.
I cant say I'm keen on the idea, leverage looks to be wrong for lifting the wheel straight up. I know proof of the pudding but i dont want to find I've wasted 50 quid.
I wonder how many top third wheel bearings get damaged by using a gear puller?
As the Begeon 6016 is a tapered, it does have to push up at a slight angle as you slide it in. But I do it gently, and rotate it round, so I'm levering in all directions.
I also wonder about the possibility of damage from a Presto type puller. They are quite large and ungainly for such a delicate wheel.
I think Alex's solution of two bits of brass tube is a winner. It's cheap, easy to make, will not mark the movement, and easy to get a vertical lift on the wheel.  Although I have the 6016, the next time I need to remove a wheel, I'm going to make some brass tools.
...the business end what gets close to the movement is really only the teeth and the 'delrin' material that posts for leverage, and that wheel is usually the tallest piece on the movement. I like levers for hands but with the wheels the presto feels more like pulling a cannon pinion. I have enough confidence in it that once I ensure the teeth are properly located a quick controlled squeeze does the job.
Really not perfect for 5-spoke wheels. You can see clearly the pivot bending. He tries to conceal that by changing positions of the tool.
Frank
Frank
Yes, I noticed that too. I'm thinking of making a saw cut down the middle of the brass rod, so that it straddles the spoke of the wheel and keep the leverage closer to the midline of the wheel.
His brass rods look too big to be able to get them directly opposite  each other. A smaller pair should work better with the 5 spoke spacings, brass might bend though so maybe better in titanium.
But where would I get titanium rod ?  Can you file it ?
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
