Small update on this long lating restoration thread... I was informed today that the part I was waiting for was sent back to France, since "it could not be delivered"... German Post are usually good working people, but lately there are a lot of strikes due to cuts in funding, salary raise denials and who knows what else. Long story short, I was ALWAYS present at the address where the part was supposed to be sent to (my office...) and no postman came knocking on my door (at least with an envelope from France, that is). Feeling quite disappointed... since the envelope was sent back to France on the 24/8, and as of today (4/9) I haven't received no communication whatsoever from the seller.
I just sent him an email, to know what happens next. One thing is sure: I will NOT pay again for the shipping back to me.
Will keep you posted.
Geo, I just received an email from the seller:
"have a look below:
RK000747861FR   Lettre Recommandée Internationale 24/08/2015 FR Arrivée en France
24/08/2015 Arrivée en France FRANCE
(FR)
Détails de l'acheminement
le 21/08/2015
Tentative de distribution infructueuse  ALLEMAGNE (DE).
le 07/08/2015
Arrivée pays de destination ALLEMAGNE (DE).
le 06/08/2015
Départ de France  ROISSY COURRIER INTERNATIONAL PIC (93).
le 04/08/2015
Pris en charge à NEAUPHLE LE CHATEAU (78).
so they try to delivery it at you address 07 of august!!
i never received it back for the moment
regards"
That's all....
On a side note, I found on another french online shop a NOS case for my Gigandet, but do not know if it would fit...
A picture of the case:
What do you think? This is how the dial looks:
Edited by GeorgeClarkson
new reply from the seller... I am starting not to like it:
"so if i understand well,
in Germany they don't even try to delivery but they send back…..ouahhh!!
so who's fault is it if you don't have your parts?
when i will get it, if i get it, i will let you know….for the moment it is in France (where? i don't know)
regards"
My Reply:
"Should I be the one to blame if the German Post did not even try to deliver it to me? I would like to end this story in a friendly manner, so I will wait one more week untill you get the parts back (if you do). In this case, let me know, and then we’ll decide how to proceed, ok?"
Please be advised, all of the forum members, that I am posting the emails text I am exchanging with this particular seller not to bash him, but just to share my experience.
And last email:
"i don't blame you
i just don't understand why they send it back to me….
don't worry my goals is to make my customers happy and i will send you back
if i don't get it back, i will make an enquiry and they have to refund me…. and i will send you your parts"
Now I feel better... Let's see what happens.
Indeed, Geo... Although I am quite p*ssed at the fact that the German post failed even to try to deliver... I know the postman and asked him several times if he had something from France, always to get a no as answer... Only wondering if the seller wrote my name wrong...
New update on the 7733 saga!
The part arrived to the seller, who sennd it back (this time to my home address....) the very next day. As of today, 17/09, the parcel has left France and is on the way to me. Cross your fingers!
Quite an adventure George! Being very impatient myself, I wouldn't be able to sleep for days until the parts arrive. Good you kept cool about it! Hoping for the best!
Cheers,
Bob
And finally, today I received the missing parts from France... Very nice packaging indeed. If I can I will go tomorrow in the office and see if I mange to install them. Wish me luck!
So yesterday I installed the flyback lever and had some trouble with the start/stop pusher.. Basically it didn't go back all the way when pressed, so the split function was not working. After a lot of investigating, I found out that the chronograph plate was slightly bent downwards and had some metal that was touching the lever joint point, impeding correct return. A bit of bending, some filing and it now works 99% of the time. It is still not perfect, but it works.
But then another problem arose: the chronograph works perfectly, but at the turn of the minute, the minute counting wheel is dragged twice by the tooth on the second counting wheel. Basically the wheel that is engaged by the tooth is too close to the seconds counting wheel. I tried to regulate the distance with the corresponding screw as best as I could but I just cannot hit the right spot... What do I need to do for a fail-safe regulation??? Please help!!
Hi George, I'm glad you are almost finishing your job with the valjoux 7733.
I would like to help with this final problem you have with the minute counting wheel, but when I reassembled mine it worked fine without any adjustment. Could it be in your case it is little tension in the spring that brakes the minute wheel? Certainly you already have noticed that the tension of  this spring can also be adjusted, changing slightly its position.
Hi GuiBer, I did notice that small spring, but that is not the problem: the problem is the position of the wheel that engages the minute counter wheel: either it is too far away, so no minute is counted, or too close to the seconds counter, so the small tooth on the seconds wheel engages first one tooth, then another, actually counting 2 minutes.... I have made a small video, but will be able to upload it tomorrow only.
After a bit tinkering and fiddling with the regulation screws, I managed finally to get it right. I had moved inadvertedly the regulating excentric screw of the minute recording jumper (part 8270), the one GuiBer refers to.
I repositioned it so that now the chronograph runner (part 8000) hits perfectly only 1 tooth on the sliding gear (part 8100).
The movement is now complete and working perfectly. Finally... :woohoo-jumping-smiley-emoticon:
I am uploading the video and will post it ASAP.
Well done George! :)
Thanks Geo ;) I am pretty happy with the final result. Probably it is not perfectly regulated as per watchmaking standards, but it si running well, and the chrono function is also working as it should. So I am happy, being this my first Valjoux ;)
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
