Small update on this long lating restoration thread... I was informed today that the part I was waiting for was sent back to France, since "it could not be delivered"... German Post are usually good working people, but lately there are a lot of strikes due to cuts in funding, salary raise denials and who knows what else. Long story short, I was ALWAYS present at the address where the part was supposed to be sent to (my office...) and no postman came knocking on my door (at least with an envelope from France, that is). Feeling quite disappointed... since the envelope was sent back to France on the 24/8, and as of today (4/9) I haven't received no communication whatsoever from the seller.
I just sent him an email, to know what happens next. One thing is sure: I will NOT pay again for the shipping back to me.
Will keep you posted.
Geo, I just received an email from the seller:
"have a look below:
RK000747861FR   Lettre Recommandée Internationale 24/08/2015 FR Arrivée en France
24/08/2015 Arrivée en France FRANCE
(FR)
Détails de l'acheminement
le 21/08/2015
Tentative de distribution infructueuse  ALLEMAGNE (DE).
le 07/08/2015
Arrivée pays de destination ALLEMAGNE (DE).
le 06/08/2015
Départ de France  ROISSY COURRIER INTERNATIONAL PIC (93).
le 04/08/2015
Pris en charge à NEAUPHLE LE CHATEAU (78).
so they try to delivery it at you address 07 of august!!
i never received it back for the moment
regards"
That's all....
On a side note, I found on another french online shop a NOS case for my Gigandet, but do not know if it would fit...
A picture of the case:
What do you think? This is how the dial looks:
Edited by GeorgeClarkson
new reply from the seller... I am starting not to like it:
"so if i understand well,
in Germany they don't even try to delivery but they send back…..ouahhh!!
so who's fault is it if you don't have your parts?
when i will get it, if i get it, i will let you know….for the moment it is in France (where? i don't know)
regards"
My Reply:
"Should I be the one to blame if the German Post did not even try to deliver it to me? I would like to end this story in a friendly manner, so I will wait one more week untill you get the parts back (if you do). In this case, let me know, and then we’ll decide how to proceed, ok?"
Please be advised, all of the forum members, that I am posting the emails text I am exchanging with this particular seller not to bash him, but just to share my experience.
And last email:
"i don't blame you
i just don't understand why they send it back to me….
don't worry my goals is to make my customers happy and i will send you back
if i don't get it back, i will make an enquiry and they have to refund me…. and i will send you your parts"
Now I feel better... Let's see what happens.
Indeed, Geo... Although I am quite p*ssed at the fact that the German post failed even to try to deliver... I know the postman and asked him several times if he had something from France, always to get a no as answer... Only wondering if the seller wrote my name wrong...
New update on the 7733 saga!
The part arrived to the seller, who sennd it back (this time to my home address....) the very next day. As of today, 17/09, the parcel has left France and is on the way to me. Cross your fingers!
Quite an adventure George! Being very impatient myself, I wouldn't be able to sleep for days until the parts arrive. Good you kept cool about it! Hoping for the best!
Cheers,
Bob
And finally, today I received the missing parts from France... Very nice packaging indeed. If I can I will go tomorrow in the office and see if I mange to install them. Wish me luck!
So yesterday I installed the flyback lever and had some trouble with the start/stop pusher.. Basically it didn't go back all the way when pressed, so the split function was not working. After a lot of investigating, I found out that the chronograph plate was slightly bent downwards and had some metal that was touching the lever joint point, impeding correct return. A bit of bending, some filing and it now works 99% of the time. It is still not perfect, but it works.
But then another problem arose: the chronograph works perfectly, but at the turn of the minute, the minute counting wheel is dragged twice by the tooth on the second counting wheel. Basically the wheel that is engaged by the tooth is too close to the seconds counting wheel. I tried to regulate the distance with the corresponding screw as best as I could but I just cannot hit the right spot... What do I need to do for a fail-safe regulation??? Please help!!
Hi George, I'm glad you are almost finishing your job with the valjoux 7733.
I would like to help with this final problem you have with the minute counting wheel, but when I reassembled mine it worked fine without any adjustment. Could it be in your case it is little tension in the spring that brakes the minute wheel? Certainly you already have noticed that the tension of  this spring can also be adjusted, changing slightly its position.
Hi GuiBer, I did notice that small spring, but that is not the problem: the problem is the position of the wheel that engages the minute counter wheel: either it is too far away, so no minute is counted, or too close to the seconds counter, so the small tooth on the seconds wheel engages first one tooth, then another, actually counting 2 minutes.... I have made a small video, but will be able to upload it tomorrow only.
After a bit tinkering and fiddling with the regulation screws, I managed finally to get it right. I had moved inadvertedly the regulating excentric screw of the minute recording jumper (part 8270), the one GuiBer refers to.
I repositioned it so that now the chronograph runner (part 8000) hits perfectly only 1 tooth on the sliding gear (part 8100).
The movement is now complete and working perfectly. Finally... :woohoo-jumping-smiley-emoticon:
I am uploading the video and will post it ASAP.
Well done George! :)
Thanks Geo ;) I am pretty happy with the final result. Probably it is not perfectly regulated as per watchmaking standards, but it si running well, and the chrono function is also working as it should. So I am happy, being this my first Valjoux ;)
    • Hey everyone! I sure this topic has probably been discussed before, but I want some good recommendations based on experience or knowledge about a good affordable high torque DC motor that I can use for my lathe. I have a little lathe but it has the regular old style motor that was used in the past with a foot controller. However, I would like to improve it by buy a nice motor with a speed controller so I don’t have to use my foot. I would like the motor to have really good torque so that even if I run it at a very low speed, it still can cut material easily. I saw online this brand called Servo sewing machine motor with a speed controller, but I don’t know how good they are and if they would work like I would like to for my lathe. Thank you for all the help!
    • Your only partially correct here. Let's look at a magnified view of the image up above. Then for a flat hairspring to function correctly there has to be a little bit of breathing room unfortunately. If you would like Better timekeeping if you get a watch with the over coil hairspring then those regulator pins are supposed to be as tight as possible but still allow the hairspring the slide. With if the pins are opened up at all you'll see a dramatic timing change based on amplitude. So in our example down below initially hairspring is basically free-floating not touching anything the effective length of the hairspring is at the stud. As the amplitude picks up at some point in time they hairspring will just tide should one pin on one swing and the other pin on the other swing. As soon as it does that it changes the effective length to being closer to the regulator pins. As the amplitude picks up more and more it's obviously touching the regulator pins more and more and the length of the hairspring shortens the watch speeds up. This is where in your video at around 16 minutes he opens up the regulator pins and the watch slows down. This is because they hairspring is no longer bouncing off either pin as much. Then because the watches running slow he speeds it up just to show that yes you could regulate the watch but now you have a problem. Because the regulator pins are much farther apart amplitude is going to have a much greater effect. Like in the image down below they hairspring is properly spaced between the pins. But if those pins are farther apart the effect of amplitude will be much greater. So he speeds up the watch to cancel out the effect of the regulator pins at the particular amplitude which was dial down then when he moves the watch to a crown position which will always have an amplitude decrease because the amount of friction on the sides of the pins now the hairspring is not touching the regulator pins as much and the watch dramatically slows down.   Let's look at the other example image. In this particular example they hairspring is actually touching the regulator pin at restWhich means the effective length of the hairspring is at the regulator pin the watch runs fast. As the amplitude picks up hairspring will lift off the PN moving the effective length towards the stud which is why the watches slowing down. As you can see is the amplitude picks up They hairspring is not centered C not getting even timekeeping and the watch is slowing even more down. But at some point in time when the amplitude gets high enough this will depend upon the watch the spacing Excedrin whatever the amplitude is will be balancing actually between the pins in the watch will of course speed up and then at some point time you reach that sweet spot where it's bouncing between the two pins but as you can see it's at a much higher amplitude. So this is why hairspring has to be properly centered between the pins and the pins have to be at the right spacing otherwise you going to get strange timekeeping based on amplitude which no matter what you're going to get a little bit of that as you do have to have a little bit a spacing. At least on a flat hairspring.
    • My understanding is that In the Etachron system the spring is only centered n order to set the stud angle when the the pins are wide open and the regulator block in at the midway point.  After that the pins are rotated in one direction only so that the width between the spring and one of the studs is 1/2 width of the spring. This results in the spring always being closer to one stud than other one.
    • The idea is that the spring is centred between the pins when at rest. Then when the watch is running it will oscillate equally between the pins i.e. bounce off one pin then the other, as the hairspring breathes. If the spring is only hitting one pin, then it isn't centred, and most likely the pins are too far apart. Yes, the regulator pins are there to adjust the effective length of the hairspring. The spacing of the regulator pins should not affect the amplitude.  The vertical positions typically have lower amplitude than the horizontal ones. This has nothing to with the regulator - hairspring interaction. Increased friction in the verticals sucks energy from the system and reduces the amplitude. If the amplitude is less, the breathing is less. More tim between the pins = more effective length. Depending on how well the hairspring is centred, and which direction it sags, some vertical positions might run faster than the horizontal ones, and others slower. For example, if the spring is off centre towards on pin, and pressed against it by gravity, it might never bounce off that pin => faster. At the position 180 deg. away, the spring will spend more time in between the pins => slower.
    • Thank you all for the tips and insights. I'm looking carefully at the Sherline lathes with a milling attachment. I need to figure out exactly what I'd need to get in terms of the base lathe and attachments to be able to fabricate basic parts and learn how to fabricate some of the less basic ones- like a cannon pinion. Thank you again.
