Looking for movement holder/spacer for Wenger Swiss Military Watch
Hi. It’s either riveting or welding . I have seen some small home made welding tools on UTube at times may be I should have a go at building one, they are small spot welding machines. Suitable for the likes of these type jobs. -
By transporter · Posted
