New member here. Jack by name and so very new to watches.  Here is the first of what I am sure will be many questions.
I was on the OTTO FREI site looking at Sellita 210 parts and noticed that cannon pinions are available in different heights. I can only guess why this is.
How does one know which height pinion should be used and in what circumstances??
Thanks in advance.
Jack
 Different canon pinion height is to accomodate for relevent complications on the base caliber, so if your watch doesn't have date or no other complicarion( base caliber)  it requires shorter canon pinion, complicarions take up some space therefor require longer canon pinion.
 Google says sellita 210 is compatible with ETA 2i01, so if you go to Dr ranfft's site, you will find variants of ETA 2801 which often corresponds to different complications, thus requiring  canon pinion of different height.
Data sheets show all parts of a movements and their relevent tech specifications.
Welcome to the WRT forum.
Rgds
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
Nucejoe has given you a good answer.
