I have just received a IWC Da Vinci for servicing for the first time. Before I get started, I'd like to get some technical advice from Mark or anyone who has serviced this movement before.
I'd appreciate it if I get some advices on how to separate the calendar block from the movement. And is there any complication in attaching back the calendar block later. The amplitude of the watch is around 200 and my intention is to service the time keeping mechanism but not the calendar mechanism.
Thanks in advance.
Thought of sharing some pictures, smartphone quality though.
The complaint is the chronograph seconds hand not able to reset back to zero position.
Checking on the Timegrapher showed an amplitude of 200. So it badly needs a cleaning and oil.
The seconds hand dropped off when the movement was taken out from the case. A loose hand but cleaning is needed. Googled to check how the perpetual calendar works. Very little information available online, so it's better leave the calendar system alone for now. Hopefully will get to watch a video from Mark on setting the perpetual calendar. [emoji6]
Today managed to remove all the hands as the month and day hands were very close to the face of the dial. Loosen two tiny screws at the side which hold the dial feet and the dial is off.
Found three screws holding the calendar block to the movement. After putting aside the calendar block, proceeded to dissemble the 3750 movement for a good cleaning in the machine.
Hope this will provide a little information on this movement. Thanks and comments are welcome.
Hopefully one day will be able to learn how to set the calendar system.
Cheers
I do like a challenge Stephen, but rather you than me with this one.
I did some research regarding the calendar module and it is absolutely mind boggling. The calculations and design work that have gone into producing it is amazing. It is a truly wonderful looking timepiece, and I look forward to reading about your progress. :)
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
