Mark posted this video - which might explain what your are seeing in an extreme case
I would add that depending on how tall the seconds hand pinion is, this could also be 105 or 106 to accommodate the extra height of a calendar complication. But I don't know how those were packaged, especially since this does not include the dial rest plate. Those would have different dial plates and you don't seem to have any at all.
Hi was the watch running before the service ? Because the symptoms you describe would point to lack of end-shake on the balance staff. Best to power down the movement remove the fork and try the balance on its own using a blower to power the balance, it should rotate for some time quite freely. -
Hi. Run a little wd40 under the screw around the flange and leave it for a while then re try. If it’s just turning on a bad thread put a screwdriver under the flange and apply a little pressure upwards and unscrew whilst under pressure -
Does this happen both with and without the fork? Photos of what you've mentioned would help.
