Best way to remove stuck crystal
Hi guys, I have a Wakmann Regatte I am trying to remove the crystal from and would like the best way to do so without damaging it. The watch has an inner rotating bezel, then the crystal goes on top with a chapter ring in between (no tension ring). The crystal on this one is stuck, and I know that these crystals are impossible to find so I need to figure out the best way to remove it without causing damage. I was thinking to heat the case up and try pushing it out. I don't want to use a crystal press to push it out because I see that there are small cracks in the crystal so I am worried that using the press will cause further damage. If anyone has any ideas on how best to proceed, it would be highly appreciated.
    • Someone just made me aware that no images are showing in my post ( ). Could someone with the proper permissions check this? I believe the images are ones I uploaded to the site, but they could also be ones I shared from my OneDrive, which had an issue some time ago.
    • I would have jumped all over that set if it had come across my Ebay search results !  Very nice , well taken care of. I probably buy 10+ staking sets a month for my restoration hobby and think you found a very nice set, at a great price that should last you a lifetime.
    • Here's another old tool that doesn't get used much, but has saved me many hours and headaches when it has been.   This is a depthing tool, but quite special. The depth can be set (or measured) very precisely with the micrometer to the right, with a direct reading of the actual center distance between the wheel and pinion. It originally came with a set of the little plates in the slots to the right that take the pivots (first pic), most of mine are missing but they can be made when needed. The section that takes the right hand wheel can be adjusted in height. And it can be set on a profile projector if needed to check things. This one is marked Tripet, but most I have seen are marked Hauser. All of them were made by a small company in La Chaux de Fonds (can't think of the name now).
    • This would be the case on a chronograph movement but the Ronda 515 doesn't have an AC contact. Here's an example of a Seiko movement with the AC Reset.
    • There seems to be a way to "short" the thing to what they call an AC Reset... Makes a bit of sense, only problem is that i have  to firstly re-assemble the movement.
