Orator Chronograph
Hi, my first posting, I will try not to step on any ones toes!
First thanks to Mark for his videos, they are an insiration.
My question is about an Orator chronometer I have been cleaning, it has a Landeron 47 movement. The dial is severly corroded (see photo) post-1266-0-88856600-1437040218_thumb.jpand probably not reconditionable. There is an Orator dial from a Landeron 48 movement advertised in the States, quoted as 33mm dia. My 47 movement dial is 34.5mm dia. Any idea if the dials are interchangeable between the two Landeron movements? Or where I might find a dial or maybe a reconditioner?
The movements look virtually identical in Ranfft:
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?13&ranfft&&2uswk&Landeron_47
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?13&ranfft&&2uswk&Landeron_48
If the plates, hand positions etc., are the same, then the issues are with the inner case size.
I'd go for it, myself.
PS: And welcome to the forum!
thanks Willfly, and I meant Mark's videos were an inspiration, typo trouble!
I found Dr Ranfft had answered the same question in 2008 (on another forum). He mentions 4 small changes between the L47 and 48, including two changes to allow easier access to the dial fixing screws. In fact mine is a 48 not as I believed a 47.
I'm still looking for a dial like the original which is a bronze colour with copper numerals if any knows of one,
regards
Welcome to the forum Harrison, I hope you enjoy yourself here. You may be looking fir quite some time to get a dual that matches the original style and colour of yours. Have you considered having it refinished?
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
