Hi All, I’m afraid I’m a newbie after some info.  I am trying to get an old cuckoo clock going for a relative.  The movement was very dirty and sticky so I started by soaking it in Petrol and  then oiling it. To cut a long story short after some time I got it running out of its case.  When I replaced it in its case it became more temperamental so I removed again for a closer look.  I checked the pallet fork and it was badly grooved.  Unfortunately the part is no longer available from anywhere I can find on the net.  I have spent the day trying to repair the pallets but with little success.  I feel that the answer is a new pallet fork so do any of you fellas know where I might get on from?  The clock is a Hubert Herr, I am fairly sure it is a 30 hour movement, possibly a KW60?  CousinsUK do pallet forks for several similar models but not that one.  They all look similar and I did wonder whether the pallet forks are standard on several movements.  I would be grateful for any help / opinions.
    • I put the original broken glass (whats left of it) behind the acrylic. This is how it originally looked like. A cheap clock but I like it. Very noisy when the alarm comes wake up guaranteed! 🙂
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
