I bought a set of 8 mainspring winders and a handle, off eBay from a fellow in the Czech Republic.
The seller had them listed as German, but I can't find any evidence of that.
From the pictures I guessed they were similar to the Bergeon winders.
They are in fact identical, but made of aluminum instead of brass.
They arrived in sad shape but after a few hours I got they all working and cleaned up.
There are no names or even size numbers anywhere on them. Only a logo stamped in all the parts.
The sizes also match the Bergeon size chart.
The makers mark is one I have never seen before and I can't find any information with Google.
I'm curious if anybody has seen this makers mark.
My guess is these were made 30 to 40 years ago.
And yes they do fit perfectly in a Bergeon handle and vice versa.
I know Bergeon didn't invent this design.
They seem to make tools based on experird patents just to keep them available.
The Bergeon Cannon Pinion tool was being made in France 100 years ago.
Again, any help is appreciated
These pop up from from time to time I've seen. I believe the brand/company is GB, you'll find them listed as GB Bergeon Style or GB Federwinder (springwinder).
I don't know if the company is still around. Still, almost definitely a better deal than the brass chinese sets you can get, and a damn sight cheaper than Bergeon.
Thanks for the info.
So I guess they are German.
I will likely never use the tiny ones as I am sticking with pocket watches for now,
but I'll have them just in case.
I figured out how to make them last year when I couldn't find a #12 Bergeon anywhere.
A few weeks ago I managed to grab brand new 10, 11, and 12 Bergeons on eBay.
With these aluminum ones I now have a 1, 3, 5, 6, 7, 11, 12 and 13 so I am set for mainspring winders for now.
I will probably have to fix the tiny catch pin on the wider stems, but I already figured that out from making one from scratch.
I was going to reverse engineer a Cannon Pinion Tool until a French company dumped some brand new ones on eBay for cheap.
Link please!!
Here is the eBay listing for the Cannon Pinion Tool
https://www.ebay.com/itm/255178283982
Looks like they still have some for sale
I was puzzled by the listing price because the Bergeon cannon pinion tools normally went for a lot more.
It's some French watch tool supply company that simply underpriced them.
I think most people thought they were knockoffs, but mine is genuine and works fine.
120 USD plus 13 USD shipping?
Cousins UK has this tool (the Bergeon 4854) for 75 USD (62 GBP).
Otto Frei has it for 96 USD.
Edited by JohnFrum
  • 5 months later...
I'm guessing here and i could be totally wrong with the initials G B stamped in them it could stand for Gustav Boley if they were sold/made by boley and originate from Germany in the 1950's, i've seen few on ebay in the UK with same stamp advertised as bought in the 1950's, the GB stamp could be there just to make you think they're made by boley.
Edited by valleyguy
On 2/8/2023 at 11:09 PM, Stagesmith said:
Bergeon
just a reminder about the company history. I even have a link they been around for a very long time by only within the last 10 years or so have they really done their own manufacturing. So basically previously before the new times of CNC everything they sold was purchased from somewhere else.
The meaning of this is you'll see stuff that they sell with their name on it that others were selling like the mainspring winder set obviously manufactured by somebody else.
https://www.bergeon.swiss/company/index
then we have other problem of stuff getting cloned plus of course if nobody has an actual patent copyright whatever then you might have a lot of people manufacturing the same stuff
I watched your video on youtube showing your homade mainspring winder, your write up gives the bergeon dimensions if anyone wants to have ago at making one or even a full set themselves. If it's ok with you i've added a link below to your flickr page.
https://live.staticflickr.com/65535/51890412256_d0f66b7f21_b.jpg
  • 1 year later...
On 2/10/2023 at 9:58 AM, SpringMangler said:
I have the same set and have replaced a couple of worn arbours (probably the most used 6 and 7 sizes) with the Bergeon version and they fit a treat. £24 + vat for a new arbour.
I just ordered a set of the GB winders (which stands for Gebrüder Boley = brothers Boley; a renowned manufacturer of tools).
It's really great to know that the Bergeon arbor fit as replacments if needed!!! Thanks.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
