So my wife bought me a stainless band Luminox as a wedding gift.  A few years ago I see the second hand had fallen off.  So I went to a local jeweler and was quoted $500 to fix it because it was radioactive and they needed a special license to even open the back of the watch for a battery change.
I contacted Luminox (what a joke) and was told ~$300 to get the second hand back on but would cost more if more work was needed. Oh, 6-8 weeks before they would look at it and ship to Switzerland.
Contacted a watchmaker in downtown Chicago, tells me $150 but guaranteed that more was wrong than just the second hand.  Also, that the movement was rare and expensive figured $300 for the total job.
Well, tonight I figured was the night. Our 13 year anniversary is next week and I picked up a Ronda 715LI High Cannon Pinon for $30 last year from Ofrei.  The reason it took me so long?  I was worried about damaging one of the Tritium gas capsules. Total time= 15 minutes :thumbsu:
15
Almost forgot, no picture or it didn't happen.
Dan B
37
Edited by dbals
Well done Dan, I hope you treated yourself to a well earned beer afterwards? :)
PS Nice watch!
No, have none. Brewing today a Belgium Tripel and a Belgium Wit while the wifey is working. Just not looking forward to 96 degrees Fahrenheit today- I brew outside [emoji30]
    • Than you so much for taking the time to write such a detailed and informative post. It really helps. So, another question: With the Etachron system the stud pushes into the carrier but the angle on the vertical plane of the stud is based on the carrier arm. I expected it to be flat but I have seen some movements where it is bent slight down meaning the stud is pointing slightly inward at the bottom and the spring leaving the stud is affected. Is this something that is done at the factory to flatten the spring?  I played around with manipulating the spring vertical angle as it leaves the stud and it has a significant effect on how it goes through the pins and also the angle of the coils on the other side of the balance. I can flatten the spring by adjusting the angle it leaves the stud. Now I know the NH35 is a mass produced movement so not the best quality but is the stud vertical angle ever manipulated to flatten the spring?
    • Because the water is very hard with calcium where I live, and I saw that on a youtube demo 🤔... Maybe it's unnecessary...
    • Why deionised water for a pressure test?
    • Yes, the t-rest hight is not critical when using this method.
    • Just received today: For only ~60$ * (*) ~140$ with shipping and custom fees. 3.80 Kg The pressure should be able to reach up to 6 bars. The glass is thick The closing system seems to be sturdy.   The plunger lever(?) and the valve: The plunger lever locking system (I will make a notch on top to note the opening position): I put 3 bars at let it for 20 minutes, the pressure didn't leaked at all.   Next steps: Quick wash, maybe put some silicone grease on the seal of the lid ?   First test I'll do: Put deionized water til the red line Put a diver case in the tank, keep it outside the water Pump (10 ~ 20 times?) to reach 3 bars (0.3MPa) Wait at least 1 minute Dip the case into the water Gently release the pressure and observe To be continued... All comments are welcome
