Hi
I am having a problem with part nos for this movement. I was putting back the minute train bridge and the screw pinged out of tweezers. This is shown in the diagram as 5462 which is the same as for the ETA 2824-it has a countersunk chamfered head. Ordered a new one but the head is 'just' too small and does not hold the bridge. Cannot for the life of me find a Sellita screw if indeed it is different. Could use a bigger head screw which will hold, but not centre the bridge.
Any ideas?
Many thanks
Simon
I came across this in AliExpress recently.
SG$ 2.69 | Movement screws  Watch Accessories ETA   2836 2824 2834 2846 2671 2892 Movement clamping plate automatic screws complete
https://a.aliexpress.com/_mrWOnfs
Can't understand the English translation descriptions but if you could identify the missing screw from the pictures, this might be a viable solution.
Hi all and thanks for answers.
Yes to Kalanag, that is the devil. Nucejoe believe me I have tried everything but it pinged hard! And Hectorlooi, there are a couple of maybes in there and will get them just in case but I did buy 3x 5462 's from Cousins and they were just undersized.
Any other suggestions or maybe someone has a bridge and screw I can buy? Mine is the original bridge in an elabore movement but maybe its that  at fault.(had to take the keyless apart because I had undone the stem screw too much.....yes I know.
Many thanks
Simon
    • Thank you @Mark. I only became a Patreon subscriber 5 or 6 months ago, but I draw so much value here. If you come up with future contribution or support opportunities, I will be on board.
