i always tell myself "save up and purchase the better watch you have been waiting for"
of course it's always harder to do than say. and so i could not pass on  a Timex purple dial.
i did do a little research and got to glimpse at the manuals for timex movement 50 and 52 generously provided by Watchweasol in another thread.
for starter, i am trying to figure out what possible faults there are so that i can better direct my focus on getting this watch running.
thank you all.
watch says: dial england,  96951-06678,  988 inscribed on movement. 2 jewels, taiwan
would it be a model 42 or 52 ??? or different
the main issue  is that i replaced the battery and it does not work.
As i shake the watch for 10 seconds it starts running and i can wear it.
but as soon as i stop movement, the watch will stop within the minute.
and of course i can not be on the move at all times so in an hour's time i could loose a few minutes already.
It sounds like you're not getting any power to the coils.
I can't really tell from the photo, but a common problem with Timex Q Quartz was the trimmer capacitor wasn't soldered to the pcb properly. Have a closer look at the trimmer and see if the joints are soldered or glued?
BTW the movement looks like a M73
thx Hector, will take some time to research a little more. i believe i understand 99% of what you are saying but first i have to refamiliarize  myself with all those parts and terms.
one instance i did experience with another q quartz was that the end coil had a wire connected to the plate and after resoldering it, the watch worked (just a regular quartz movement).
Oh noooo,
now this is what has become of my watch. Will try to put it together when possible.
how can i take the movement out?
 From the front i am guessing? But do i remove the bezel then pull out the crystal with a crystal puller?
i did try that with a bezel remover but no success. If it is how it’s supposed to go, I’ll try again with just a blade.
 Any help would be greatly appreciated.
Oh Boy! I hope you took plenty of photos along the way.
Timex Q Quartz are usually front loaders. You will need a crystal lift to remove the crystal, then everything will come out from the front.
If you are planning on working on many Timexes in the near future, then invest in a good crystal lift like a Bergeon or a vintage Vigor. The Chinese and Indian made ones don't seem to last very long.
Hector is right.  I have worked on Timex Electrics also.  You open the back only to remove the cover over the movement, and to release and remove the stem.  Then you use a crystal lift to take the crystal off and the movement comes out the front.
They can be tricky to work on; I've had practice on a handful of them and I still find them different at times.
Edited by KarlvonKoln
