Introduction
By nickelsilver · Posted
It's either bent or hung up on something or both. The hexane won't hurt it, and hanging from a balance tack indefinitely won't hurt it. Â If the spring is glued to the stud there's a chance that the glue was softened and the outer coil stuck to the stud. Haven't seen that happen, but I suppose it could. Don't know if hexane affects the glue used either. -
Hello all. some help required here from the community please. I serviced this movement, which was running reasonably well, but the balance spring which was running healthily before I started, after cleaning in hexane for 30 secs, is all bunched up at the stud. I did store the balalance on a tack thereafter for a day. Â could the spring be strained under gravity? I demagnetised of course, and the balance is squeaky clean. some help would be much appreciated. Thanks, Tony G Â Â
Hi, I was wondering if you had been able to find the crystal reference code for the 0903-7030 I'm in a similar predicament. Thanks.Â
