Carriage Clock help
tyl
You need to oil the escape wheel teeth every other one so the pallet pins will catch some. The two cups that the balance wheel sits in a pocket watch oil for them. Here is the back plate which I have marked for you in red, these places need oil and the same on the other plate, just be careful not to over fill the oil sinks as you don't want the oil to run out over the plates. WIndels clock oil is the best. Don't for get to oil the mainspring in side the barrel.
Edited by oldhippy
Success; it is running again.  Your help is much appreciated.  And I learned a lot.  For one thing - I am no clockmaker and have a lot of respect for those who are.
After repairing the hairspring tediously the first time, I installed the balance wheel and with tweezers finally got it to thread into the regulator stud - a very small hole.  Tested and it absolutely would not run - at all.  Then I noticed that the hairspring was all out of kilter again.
Removed the balance wheel again and spent about seven hours on the hairspring for the second time.  Reinstalled the balance wheel again, tested, and it did the same - would not run at all.  Again noticed the hairspring was all out of kilter.
So I went to Youtube and watched a video of a fellow removing a Westclox balance wheel;  it is found as "Westclox balance wheel remove and install."   I then realized that I have been deforming the hairspring by pulling it through the regulator tab with tweezers and into the regulator stud - that if the hairspring is coiled properly it should thread into both.
And that solved everything.  Reluctantly I removed the balance wheel again and this time with less enthusiasm reformed the hairspring again (see picture).  I spent about four hours on the hairspring this time and it is significantly poorer than my  other two efforts.  But it threaded into the regulator tab and was less than 1 mm away from threading perfectly into the regulator stud hole.  (Even though I did not remove the hairspring from the balance wheel, after reinstallation I noticed that the pallet pin(?) was oriented at the bottom and would not click the paddle(?) so the minute hand would not advance.  Referring to the youtube video, I placed a small screwdriver blade in the collet crack and rotated the balance wheel so that the pallet pin is on the top.  That worked.)
When I wound and started the clock again, it would only run for about 50 clicks.  After experimenting with the regulator some ten to fifteen times back and forth, it seemed to take life with the regulator (surprisingly) at exactly the twelve o'clock position.  It has now run for seventeen hours and I call it good.  The hairspring is no longer beautiful but seems to be good enough.1934822535_Carriageclockworkingagain.thumb.jpg.15414f4b69a48e776ede29bd2c06cc85.jpg
To everyone, thank you again for your help.  I have now breathed life into this old clock after many years and have a much greater appreciation for the craftsmanship of the maker.
Edited by tyl
Corrections
That looks better for a first time. For what its worth I started back in the early 70's as an apprentice I did a 5 year apprenticeship then another 2 years as an improver learning all about watches and clocks this included making certain parts for watches and clocks.
The clock is running but quite fast.  I saw a post by Vich from about 2015 and he had the same 8 day Schatz carriage clock.  Now  I am wondering if it is possible to purchase another hairspring or a complete balance wheel with hairspring.
Have searched the internet for a week and find nothing.  Not even in China.
Thx for the help. Or do I dare remove the hairspring again and try to get it in better shape?
From what I can see where you have pinned the hairspring it has a lot that is passed the pin.  What you need to do is unpin it, remove the complete balance, mark the wheel so you know on the wheel where the hairspring was pinned,  then judge where it needs to be pinned nearer to the end of the hairspring, this will make the balance out of beat so remove the hairspring and re position to the mark. Because you have let the hairspring out it will gain less time in fact it should lose. if it is keeping better time you should be able to use the proper regulator to adjust  time.
This is a trial and error practice it might take a few goes.
Edited by oldhippy
https://www.cousinsuk.com/product/hairsprings-clock
I got a box of these from Cousins. Only used 1 so far to replace a really mangled hairspring. The quality isn't great but useable in a pinch.
But you will have to do minor alterations like broaching or closing the collet to fit the arbor. Then you'll need to "vibrate" the hairspring to get the correct length. And you'll need to form the endcurve.
Perhaps you should get a box to get some practice on hairspring work.
The pic was deceiving.  The hairspring extended only about 1mm from the stud and pin.  I removed the pin and backed out the balance wheel until the hairspring does not extend at all and pinned it again.  Now I am testing it again.  The hairspring cannot be let out more.
It was not a happy camper.  I had to adjust the regulator a few times but now it has run all night.  Still gaining about the same amount of time.
(Because I lost the pin weeks ago I have used a vinyl coated wire as a pin.  What you can see mostly in the old pin is that stripped wire which extended some 2mm; it took a close visual to see the difference in the new wire pin and the hairspring.  I ordered some pins but when they arrived they were way, way too thick.   So I am going to stick with the wire.)
I am still trying to understand the last directions from oldhippy.  But if the hairspring cannot be let out more, I am not sure there is anything I can do.
Which part do you not understand?
I think the endcurve is not shaped properly and the 2nd coil touches the hairspring stud when the hairspring expands. Check that the 2nd coil has enough distance from the stud. Perhaps you could tighten up the coils a little more and try to get more even spacing between the coils. Use the distance between the inner coils as a reference.
Having haphazardly followed this thread I have to ask, are you removing the hairspring to manipulate it?
if you are you need to start at the first incorrect bend in the spring that’s closest to the collet and get that true and work you’re way around until it’s perfect.
You will find that the bent out of shape spring is probably not acting as it should with the index pin on the regulator
Transporter and Hector - after close examination I think you are right; it looks like coil 2 from the outside may be touching coil 3 at about the 9:00 spot (it is not touching the regulator stud).  A close inspection shows that the coils on the 9:00 side are significantly closer together than on the 3:00 side.  So close that I cannot tell for sure if more than coil 2 and 3 are touching - but now I believe it is only coil 3.
  I have worked the hairspring without removing it from the balance wheel.     Granted from the last pic I sent it looks pretty bad.  For example coil 1 is some 3X farther from coil 2 than coil 2 is from coil 3.  And overall the hairspring distance from the balance wheel spine to the outside is about 50% greater on the 3:00 side. Spent probably 30 hours trying to correct it.
The first two times I defeated my effort by pulling it through the regulator slot and the stud not knowing that it should be carefully fed through the slot and stud by moving the balance wheel.  The third time I fed it through successfully; however I ran out of patience before that and spent much less time trying to true the hairspring.  The hairspring looks pretty poor; much more so than my first effort.  That is why I asked about the possibility of finding a new one.
My 6 June post shows the hairspring at last effort.  This is what is in now and it is running but still gaining about 10-15 minutes each twelve hours.  I really dread taking it out and working on it again - but if the forum agrees that it looks too  bad to keep good time, maybe I will do so.  Putting it off for now.  Oh for a new hairspring
Oldhippy - not sure what you mean about mark where it was pinned.   "... so you know on the wheel where the hairspring was pinned,  then judge where it needs to be pinned nearer to the end of the hairspring..."    With the balance wheel removed how would I know where the hairspring was previously pinned?  Would there be a crimp in the hairspring?  But now I have straightened it out and recurved it three times and have repinned three times.  At present none of the hairspring extends out the other side of the regulator stud; it is pinned at the absolute end of the hairspring.  I cannot let it out any more.
If you take another look at the 6 June post maybe you will judge that the hairspring is just not repaired/recurved well enough.  Since I cannot let the hairspring out any more, I am guessing that I created my own problem by doing such a mediocre repair of the hairspring.
If you will review the post just above, you will see that the right side of the hairspring is a good deal looser than the left side.  It certainly does not look like that in 6 June post, in fact it looks pretty evenly balanced, but after installation and pinning, it looks somewhat unbalanced now.
From youtube video - locate wide spot in hairspring and go 180 degrees to the other side; make correction there.  Do you agree?    Not intuitive.  Or do I just start at the wide spot to begin the recurving?
Thanks to all for the help.  Need to reset the clock ten minutes earlier now.  Any way to send a video of the clock running through this forum?
  • 2 months later...
  • 9 months later...
The Schatz 8 day clock continues to run well.  This morning I watched on public broadcasting an English show named Travelling Auctioneers.  The lady said that technically my clock is not a carriage clock because it has a single mechanism and therefore does not chime.  She says the proper name is a timepiece; that to be a carriage clock it must have two mechanisms and be able to chime.
Not everything on TV is accurate.  Is she correct that I have a Schatz 8 day timepiece and not a carriage clock?
Thx.
It is in fact a Schatz 8Day Anniversary Clock Visible Wheel Movement 2Jewel.
Silly woman. Carriage clocks are called so because it has a handle, you get them most are 8 day duration. Timepiece 8 day, Timepiece and alarm,Strike 8 day on a bell or gong, also with or without alarm,   Grande Sonnerie and et petite sonnerie strike these are complicated strike and chimes. She is also wrong carriage clocks are not made with just a chime.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
