Beginners clocks
To work on clocks safely a spring winder is a useful tool when replacing broken springs, expensive to buy but quite sraightforward to make. If you need one I have the plans somewhere. I built two and a third partially done.   Cheers
As also are letdown tools for the removal of power again simple enough to make.
As Olh hippy said alarm clocks are a basic movement and not to be dismissed as training pieces. Although the mainspring doesn’t need a winder it still needs treating with respect as it can still give nasty cuts and the use of clamps is recommended.
Will look up the plans Richard, and pass then on.
Hi Richard,  just type in google  how to make a clock mainspring winder.  There seems to be a lot on the web now so plenty of designs to choose from.  a cheap let down tool is a metal tube with a slot cut in the end to fit over the actual key fitted into a handle , and by releasing the click and allowing the handle . to slip through the hand with enough force to have a braking action on the tube this will allow the spring to un wind under tension.  You may wish to purchase the retaining shells or a set of clamps or maybe even make your own shells as you need them/        cheers
A time piece with pendulum. You will need a mainspring winder. Most clocks have the springs in barrels apart from American clocks. Before I go any further I'm just going to look on ebay and see what I think would be best for you to start with.
Not much in just a timepiece. I have found these apart from one the rest are strikes but they are all working and not to expensive. I can help you with any of these it will not be a problem.
https://www.ebay.co.uk/itm/304830524278?hash=item46f950ab76:g:yYYAAOSw3-pkB2yx&amdata=enc%3AAQAHAAAAwAvPQit9ZbKPrlnlP2uJJnfwyxQLyr%2FIhkpDbk4DNLsQI%2FUI%2BtYPZ4yV4VHMwYi%2BkeX5xd%2BpGo%2BvDZxn8VVchcWSC%2B32PXaaxt2Y76CZx%2FejnYTVK%2Fe7I38P1YPdaMfdiIsETi1yixsK6%2Bd2i7YIHkOqgL4nOOOYw1L2c9piDkFsbx3rVNJ%2ByhS02GNpxgEghABwFUpHIjeWL8iANMiGo3%2Ba2h4B6mQ4Wi6h%2FWM9En67l2qzebZzTT9m7%2F8LyhVGRQ%3D%3D|tkp%3ABk9SR9bWwZ7fYQ
https://www.ebay.co.uk/itm/125825465653?hash=item1d4bc83d35:g:CoAAAOSwGV5kEvLQ&amdata=enc%3AAQAHAAAAwFaqfYJ87qWPVjv8haLw10p6bIk3M5CT6Yq3F%2BJIyf4jPsM8kV1z8rJ9WWQ9TcYPQ1e0bF0wgeb0JHk4gRqZD2v0a7W9xAZZFaCkZjDvDQ6Bp8IgRgovLQHnuWLTJo1JmtR09r%2Fy27pcy4Pbjte78d7CWz2llBqyAes5dpVz4aKmz4BMym10U0ucCiSMUXjyRXBqFcADfNhhJou56UNCFLP10nmqbptxFXPg2TmIz9kasGGfmyIT9KwlyePRJ%2FcSCg%3D%3D|tkp%3ABk9SR6LK_p3fYQ
https://www.ebay.co.uk/itm/404204572982?hash=item5e1c785136:g:dCIAAOSwGfNkEigJ&amdata=enc%3AAQAHAAAAwOJSDOHEVJUYcFo5EcbaWdD2vrecPtcawgOC7MBTshQ7W1uA%2BZC3abFdr2%2F2Oyzo7RJlZ5C0VTH9iEp%2BG1RDsyElSOv5Qse8INDAU9PNXl%2F3gDdd4S0VqrPBo2s4LOVc3TMmROWwJBZYRMY2%2BaCgdCEBLKoIf8QCSnwEBBzP3LULni4%2BjFPrzRCCGxYjF%2BuSDXjhqKFWC8da1GVLYJjPmoH61u59VogaZ7WKwt61TRbFUXjOJUqMZp6Txa2X%2BFTREQ%3D%3D|tkp%3ABk9SR97SnJ7fYQ
https://www.ebay.co.uk/itm/144990817418?hash=item21c2204c8a:g:qOYAAOSwa8dj~i5E&amdata=enc%3AAQAHAAAA4IcJCTuK%2BS87Ovzl7WFf6Qj7F%2BxUBDZ%2B%2FU2eCjXGUwOsoTrAhp5b5tzxqxgCA5dHAwi8nYlRPDjWCXsXAgkwVjfXyopbMsnayDumzUrkrM4z1CL9mQZ8aYuErT8LqfaH2AEvIbQFStIaTzEiu1%2B5gVThY7gmxh3VtVJv1ytAeKgFA1Tkz4gkIvxl%2FQCMuN4y2ACf9OzOKktmHeG6yhkX61GOTZtPr4JH6nH8TVcZq%2FpD17HwOYgR3mGZ6TrgALBTkEalaCD21wCg%2BR%2FFbZ%2B0RQ5IM0%2F3djGHeequVs7VXSbV|tkp%3ABk9SR-Dx2J3fYQ
Edited by oldhippy
Bought this one . £22.50. No doubt I'll need lot's of help but I'll do some research before asking the forum.
Hi all
Recently watched an episode of Repair Shop where the resident clock repairer Steve Fletcher whom is  certified repairer install a main spring in a barrel  by hand, which i have have myself, but only for my own clocks before buying a main spring winder. OI really don't understand how these programs can show bad practice.
40 minutes ago, Martyd said:
Hi all
Really? Which episode was that?
I know the feeling there are some butchers on Youtube, many should never be near a clock. The one that I'm always rattling his cage is someone called Scottie now he really is a test, he takes movements to pieces but never shows the actual repair then he films putting the movement back together, and he never replies to my questions.
Yes i know what you mean about Scottie, he always just takes them apart cleans them mentions about putting in new bushes, puts them back together and hey presto they are working even on a Westminister chime he recently worked on. And now he has members paying him.
The only person I recommend on Youtube is  Tommy Jobson, but he is for the very advanced clockmaker. You might like to take a look at what he does. I love watching him because a lot of what he shows is what I did many years ago. I'll have a look on the net and see what I can find. You can always ask me for help and advice I like helping.
Edited by oldhippy
I have received my clock. I know all of you will give me as much help as necessary but I need to help myself before asking for advice.  My first step is to learn the parts, next step to understand if there are any pit falls to disassembly, finally reassembly and case restoration.
Where's the best place to learn the anatomy of the clock?  Any pit falls to disassembly? Further questions to follow.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
