Beginners clocks
57 minutes ago, watchweasol said:
Hi Richard.  The center can is best left alone unless the pivot hole is worn then it needs removing using large levers as does the kidney cam(gathering pallet) to be correct.   A pair of levers or a puller, I use levers and have no problems.
Thanks, I've read that nitromors won't affect steel, is that true, if I leave the centre wheel and gathering pallet in place?
Hi Richard  It will remove paints, varnish Lacquers from many surfaces, I have used it on steel, wood and brass with no problems but you mut clean it all off thoroughly. I use warm soapy water then dry well to remove all moisture once done clean the clock in the normal way.
 Horolacq is what I always use on French Carriage Clock movements and cases. You need to get the clear, also a nice very fine paint artist brush flat style if possible. This stuff drys very quick, be careful not to handle parts with your fingers wear finger cots if you can.
The Harris MK1 clock mainspring winder is underway, photos to follow.  So far £0 but I may have to go mad and spend £20 to finish it. Hehe.
What's the best way of cleaning the bottom/ dial side plate?  Terminology?  I usually use lighter fluid followed by IPA, it would cost a fortune, could I use petrol, followed by IPA?
15 hours ago, RichardHarris123 said:
Might end up at £30, I'm going crazy.  Thanks for the help.
What sort of mainspring winder have you bought for £20 as oldhippy says they are not cheap, have you got the capture rings for the mainspring with it, what make is it and did you buy it from ebay?
Ok, after the conversation about quality tools!!!!
Not finished and very crude but it worked well. I attached the barrel to some wood with a plastic clip and held that in a  vise as a temporarymeasure.
The ratchet is removable and I can utilise different sizes of socket from the let down tool.
1 hour ago, watchweasol said:
Hi Richard   well done I like the design simple yet effctive, what did you use for the retainer, it worked well.
By the way I believe the watch (Half Hunter) is by A Schild maybe a 168 ?  inported by George Stockwell  who was a major importer at the time,  more to do.
Thank you, an advanced member like you appreciative it, means a lot.  Keep me updated on the half hunter.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
